Duel battery charging
Old Oct 28, 2021 | 10:00 AM
mikemdd's Avatar
mikemdd
2022 F250 Platinum/Power Stroke: My truck has two batteries. I'll be travelling for few months and want to put a smart charger on the battery (ies). If I connect the charger to only one battery, will it charge both or do I need to put a charger on each battery. The truck will be locked while I am away. Thanks
Old Oct 28, 2021 | 10:31 AM
2019er's Avatar
2019er
They should both charge - wired in parallel.
Old Oct 28, 2021 | 10:34 AM
crewzer's Avatar
crewzer
The batteries are wired in parallel. You can connect a smart charger to either battery and it will maintain both.
HTH,
Jim / crewzer
Old Oct 28, 2021 | 10:36 AM
mikemdd's Avatar
mikemdd
Perfect....Thank you!
Old Oct 28, 2021 | 02:27 PM
Sport45's Avatar
Sport45
I’ve left mine sit for 3 or 4 months and it started right up. Unless you’re in a really cold climate you may not need a battery maintainer.
Old Oct 28, 2021 | 02:33 PM
HRTKD's Avatar
HRTKD
As Jim said, connect the charger to either one. That's what I do. My charge is connected to the passenger side battery, only because that one is closest to the wall where the outlet is for the charger to plug into. Be sure to use a quality smart charger. Grandpa's charger may overcharge the batteries.
If you're really ****, you could connect the positive lead from the charger to the positive post of one battery and the negative charger lead to the negative of the other battery. My charger leads won't span that far, so I go to just one battery.
Old Nov 11, 2022 | 10:26 AM
WeRetired's Avatar
WeRetired
6th Gear
Thanks for input, I guess i was overthinking, hook it up don’t worry about it, thanks
Old Nov 11, 2022 | 10:47 AM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
If the batteries are DEEPLY discharged, then the choice to charge the batteries as one big battery or separately as individual batteries depends on the amp rating of the charger.
I have a 25 amp charger, and on one truck with dual batteries, for reasons beyond the scope of this response, I tried charging both batteries in parallel (that were deeply discharged) without disconnecting them individually.
It was too much for the charger. The charger is a "smart" charger, so it shut down before cooking to death (but man was it warm to the touch).
I have quick disconnects on each battery, so it was a simple matter to let the charger cool, and charge each battery separately.
The foregoing story is not relevant for simply maintenance charging of otherwise mostly charged up batteries.
However, when the batteries are deeply discharged, one may have to restore each battery separately, depending on the charging current produced by the plug in the wall battery charger.
Old Nov 11, 2022 | 11:18 AM
wheelerfreak's Avatar
wheelerfreak
I park mine for extended periods as well and plug it into a Battery Tender brand maintainer, Tender. It is a 2 bank charger/maintainer. I have used a single bank charger on just one battery before and it charged up that battery until the LED was green, I then plugged it into the other battery and that battery showed according to the LED's on the charger that the second battery still needed to be charged. So who knows if they are wired together when shut down.
Old Nov 11, 2022 | 11:58 AM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
@wheelerfreak You appear to have a 7.3L gasoline powered truck. The dual battery option in gas trucks is wired differently than the dual battery standard in diesel trucks.
The OP has a diesel truck, where the batteries are in parallel at all times, as both batteries are needed to power the glow plugs prior to start, as well as turn over the high compression diesel engine.
On a gas truck, there are no glow plugs, and the lower compression gas motor is readily started on a single battery. Therefore, a continuous duty separation relay is typically placed between batteries on gas trucks equipped with optional dual batteries, so that any electrical loads powered by the auxiliary battery while the engine is off do not drain the main battery designated for starting the gas engine. Once the engine is running, the relay is engaged to parallel the batteries for charging by the alternator(s) while underway. When the engine is turned off, the batteries are isolated again, by way of the relay.
The diesel trucks, like the OP's, do not have a separation relay, because both batteries are needed prior to starting the engine.
Old Nov 11, 2022 | 01:44 PM
Bruce M.'s Avatar
Bruce M.
Interesting info, thanks for that.^^^^
Old Nov 11, 2022 | 01:47 PM
HRTKD's Avatar
HRTKD
Yeah, I didn't know that the gas engine trucks with dual batteries were setup any differently.
Old Nov 11, 2022 | 09:50 PM
KU4OJ's Avatar
KU4OJ
Originally Posted by Y2KW57
@wheelerfreak The dual battery option in gas trucks is wired differently than the dual battery standard in diesel trucks.
I was unaware of this. What a wonderful feature. Thanks for the heads up. So now 2 questions? On which side is the starting battery? One would assume the passenger side since the starter is on that side of the engine and single battery trucks locate the battery on that side.Next question, is there a schematic available for this set up?
ON EDIT: Based on a schematic provided in another thread, I do not believe this is correct. I do think I'd like it better, though.
Old Nov 12, 2022 | 08:48 PM
Chris 86's Avatar
Chris 86
My 7.3 is not wired this way. Both batteries discharge regardless of which "side" my load is on.
Old Nov 12, 2022 | 11:07 PM
aklim's Avatar
aklim
DUEL
DUAL
