LED Headlights worth the upgrade??
Old Oct 28, 2021 | 09:13 AM
Fowlthing's Avatar
Fowlthing
Seems expensive... love to hear what people think and have experienced
Thanks
Old Oct 28, 2021 | 09:22 AM
GNR22's Avatar
GNR22
The factory LED lights are apparently made of solid gold. Quite a few members have opted for Morimotos LED and Hybrid LED lights and seem very happy with them.
Old Oct 28, 2021 | 09:25 AM
cpobst's Avatar
cpobst
I have the Morimoto hybrids on order. They look just like factory.
Old Oct 28, 2021 | 09:33 AM
fleming23's Avatar
fleming23
If you are going to get a Lariat Ultimate, adding the LEDs is less expensive, warrantied, and easier than aftermarket. If you have a Lariat Value or lower option truck, look into the aftermarket. The Ultimate package adds around $3500 + the 1200 or so for the headlights. My last 2 trucks have had factory LEDs, and I love them at night! My new truck was going to be a lesser optioned model so my original plan was to go aftermarket. Ultimately, I wanted Adaptive Cruise, and that required the lariat ultimate or better, so it made more sense for me to just add them factory.
Old Oct 28, 2021 | 09:57 AM
RidgwaySD's Avatar
RidgwaySD
I live in a rural area and do not have any issues with the standard headlights. I used ForScan to enable fogs with high beams which is nice on our roads. ANY weight in the back and I am getting flashed though... I just made a pre run up the mountain to try the new truck out in the snow. Set up to plow I have 600 lbs of tube sand as ballast. Nowhere near the overloads, F350, I am getting flashed even with just low beams and no fogs regularly. Similar with the gooseneck, just low beams, ~1300 on the pin. The standard lights work really well so just do not buy the stories about not being able to see without the LEDs.
We also bought my wife a new Rubicon and skipped the ala carte LEDs. The standard halogens on that vehicle work great too despite stories of certain blindness at night on the internet forums...
Old Oct 28, 2021 | 10:04 AM
Back2Gas?'s Avatar
Back2Gas?
Subscribed...where's the popcorn?
Old Oct 28, 2021 | 10:27 AM
GNR22's Avatar
GNR22
Same here. I think the quad beam halogens on this truck are actually very good. I won't pretend like they are superior to the LEDs, but they have a ton of throw and are a whole lot brighter than the 20+ year old head lights I'm really accustom to, or even the halogens on my '14 F150. I brace myself every time I meet another vehicle at night with any load in the bed or a trailer on. I know I'm going to get flashed. I have considered adding air bags just to keep the tail of the truck up so this doesn't happen, even though I'm not putting that much weight on the truck. Totally off topic, but I don't understand the overloads on the truck at all. I think you'd have to be double or triple the weight rating of the truck just to touch them.
Old Oct 28, 2021 | 10:33 AM
2019er's Avatar
2019er
I like mine. Don't know if I like em enough that I'd add them aftermarket, if that's what you're asking.
Old Oct 28, 2021 | 10:59 AM
4wd6.7L's Avatar
4wd6.7L
Thanks
You'll need to provide more info on what trim and option packages you intend to order. If ordering a Lariat and the Ultimate package, the LED's are absolutely worth the $1100. That not only includes the headlights but also other LED lighting on the truck, like taillights and fog lights.
Old Oct 28, 2021 | 11:09 AM
KU4OJ's Avatar
KU4OJ
The question the OP seems to be asking is "If I go to a great deal of hassle and expense am I going to be disappointed?" and the answer is maybe.
Do this first: Upgrade your fog/driving lights to LED. I did a "bulb only" swap of my halogen OEM fogs and I found they put out so much usable light I think changing the halogen headlights over to LED is unnecessary considering the trouble and expense. This $25 solution, frankly to my surprise, gives me plenty of light and it's where I got off the LED bus. (Except for backup lights, you'll want those) I used SeaLight direct replacement LEDs off Amazon.
Old Oct 28, 2021 | 11:17 AM
4wd6.7L's Avatar
4wd6.7L
If that is true, then I completely misunderstood the OP. I thought he was asking about the cost of adding the LED option to a new order.
Old Oct 28, 2021 | 11:23 AM
SomethingRandom's Avatar
SomethingRandom
I've driven SDs with the halogen lights. My current truck has the factory LEDs. I don't regret the expense. If you are in an area that gets a lot of snow, you might actually want to keep the halogens. They generate enough heat to help keep snow accumulation down.
Old Oct 28, 2021 | 11:25 AM
Parksoffroad's Avatar
Parksoffroad
Worth every penny, would do it again without question. They are crazy bright and covered by warranty so no hassles there.
BillyE's Avatar
BillyE
I was skeptical until I saw them in person. They do look factory (a little different, but not cheap/aftermarket looking), although I've never been in the cab at night so I can't say for sure the light pattern is like factory.
Old Oct 28, 2021 | 11:30 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
If your truck order already has the required package to be able to add the LED headlights, then it is absolutely worth the money.
But, if you're like me, ordering a Lariat value package, then IMO having to first add the ultimate package for $3495 and the LED headlights for another $1195, then no, I don't think they're worth that.
I have been fairly satisfied with the halogens, the 4 headlights do put out more light than my previous RAM, and I hardly ever run the high beams.
Someday, if I get a burnt out headlight bulb, I'll probably replace them with some of the higher output halogens they make, see if they do any better.
