Old Oct 28, 2021 | 08:10 AM
Jm1dd's Avatar
Jm1dd
Hi I was wondering if anyone had any idea what this noise is in this video. It’s a 2000 f350 7.3. Any help would be greatly appreciated.
(Moderator's Note: The attached video file was scanned and approved)
File Type: mov
Old Oct 28, 2021 | 03:17 PM
udsuth78's Avatar
udsuth78
A little context might help. If your just parked reving or slow rolling, any other symptoms? First guess if parked I'd say something in the belt drive possibly fan clutch. If rolling I'd say rock in caliper or brake dragging.
Old Oct 28, 2021 | 07:43 PM
Jm1dd's Avatar
Jm1dd
it’s just when moving and seems like only when you hit the throttle and at low speeds
Old Oct 29, 2021 | 07:59 AM
udsuth78's Avatar
udsuth78
Is it an auto or manual and 2 or 4wd? Any general area it seems to be coming from, front/back, engine bay? It definitely sounds rotational so I'm thinking warped rotor, but wouldn't rule out a u-joint, carrier bearing, or axle pilot bearings if 4x4.
Old Oct 29, 2021 | 08:38 AM
Jm1dd's Avatar
Jm1dd
It’s auto and 4wd can’t exactly pinpoint it since it only makes the noise when it’s moving and haven’t had a chance to have someone stand outside of it and listen while I drive. I’ll see if maybe I can put my phone under the truck and drive over it or something.
Old Oct 30, 2021 | 08:31 AM
Listor's Avatar
Listor
was having similar sound from passenger side, turned out the be my axle seal
Old Oct 30, 2021 | 09:53 AM
RacinJasonWV's Avatar
RacinJasonWV
That could be expensive. Maybe you have a really good indestructible case. Would be a good test for it.
Sorry, I have nothing useful to add. Just my dumb dad jokes. I do wish you luck on your issue.
meandyou
Jul 22, 2021 01:25 PM
Mike F250
Jun 19, 2009 10:35 AM
yardboy
Jan 29, 2008 09:29 AM
