I've all but given up. My '99 Expedition 4.6L vin6 has had every possible sensor replaced, gaskets, wires, plugs, injectors, fuel pump, filters, alternator, starter..too many to mention. Yet it will start and run a few seconds
like it should, then has no pedal response and starts running rough. During rough idle it will come in and out to where the pedal response is fine. Even vacuum lines have been replaced. Any ideas at this point? My check engine light works as do the rest, but I can't get it to throw a code??
