Sponsored by: Real Truck
Radius arms
Old Oct 23, 2021 | 12:32 PM
AUDIous's Avatar
AUDIous
Radius arms
I hit a rock late last night and it looks like i may have bent the right radius arm. My truck is a 2005, i can not find any arms for a 2005 locally. I have found some for a 2013. The oem part numbers seem to be different, however most of the aftermarket ones say they fit 1999 and up. Does anyone know if the ones for the 2013 will fit or do i need to just order the correct ones?
Old Oct 23, 2021 | 02:58 PM
Eaglescout94's Avatar
Eaglescout94
Is yours 2wd or 4? Aftermarket arms fit 05-16 4x4 so I see no reason factory wouldn’t either. If 2wd then I’m not so sure
Old Oct 23, 2021 | 03:07 PM
AUDIous's Avatar
AUDIous
its 4x4. i figured if aftermarket ones would fit so would the oem ones, but i was hoping someone could confirm that since they are different part numbers.
Old Oct 24, 2021 | 08:57 AM
speedfreak78's Avatar
speedfreak78
Ford changes part numbers all the time, it's hard to go by that unless you have access to all the obsoleted PN's before the current one. Have you tried car-part.com?
Old Oct 24, 2021 | 11:38 PM
Vadis's Avatar
Vadis
I don't have anything as old as 05 but I have a set of 08, 09 and a 11-16-ish radius arm set and they're all the same, or at least close enough to be swapped back and forth.
Old Oct 24, 2021 | 11:44 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
The front frame section changed significantly in 2008.
vidaliaman
Jan 2, 2021 07:02 PM
PIDI
North Carolina Chapter
Apr 17, 2012 07:36 AM
2112
Nov 19, 2004 09:51 PM
