66 ranchero u-joints help!
When I did a quick search on Rockauto....it shows a "plethora" of ones including the variation you are speaking of IIRR including 1.062" Bearing Cap! Yeah!!!!
1966 FORD RANCHERO 3.3L 200cid L6 Universal Joint | RockAuto
DANA 51203X {Click Info Button for Alternate/OEM Part Numbers} Spicer; Greasable Info
Rear Driveshaft at Transmission; 1.062" Bearing Cap; with 3.625" Outside Snap Ring; with Yoke O.D. 3.875 IN
I would give one recommendation....avoid SKF like the plague!!!!!!! Dana, Spicer are the best mfg's IMHO...... looks like DANA has what you hopefully need.
This is also an excellent source for part numbers and gives the exact specs as well...
North America Homepage (danaaftermarket.com)
Just plug in your year/make/model, click on driveshaft and then start reading all the specs on each of their u-joints.........................
If all else fails, try these guys...........
Bob’s Driveline Service 14215 Palmdale Road Victorville, CA 619-245-1136
Inland Empire Driveline Service 1540 Commerce St., Ste A Corona, CA 92880 951.279.8026 or 4035 East Guasti Rd., Ste 301 Ontario, CA 91761 909.390.3030
Raytech 11110 Adwood Dr. Cincinnati, OH 513-742-2111
Another option is "Classic Mustang shops..... they should have these sitting on the shelf as well....
Larry's Thunderbird & Mustang Parts 511 S. Raymond Ave Fullerton, CA 92831 714-871-6432 714-871-1883
Another option that has worked well for me is to contact Dana-Spicer direct to their sales or tech support1) asking to verify the correct part number, then if they can check to see which one of their retailers/distributors would have that item. If they can't, then google the part number, you'll find who has it.
What might help as well, is this..... The Dana-Spicer parts identifyier.....
Click on Automotive, then universal joints and then you can select by cap size for a search. If all esle fails (which I doubt you won't be successful with something out of this), then consider changing out the yoke allowing the use of a larger available u-joint.....
Hope this helps...............
The front U-Joint (C5DZ-4635-B) is different than the rear U-Joint (C5DZ-4635-A)
1966 Falcon Ranchero // 1966/67 Falcon Station Wagons // 1968/70 Falcon Station Wagons without Evaporative Emission, without low fuel level warning system.
1967 Fairlane Ranchero // 1968/69 Fairlane/Torino Ranchero without low fuel level warning system // 1970/71 Fairlane/Torino Ranchero except with 429 engine.
NOS PARTS SOURCE in Olathe HAS shows 1 = 913-220-5746. But this source rarely updates their inventory, so may not have it.
No one else has any, I didn't look on ebay. The part numbers prefix can also be typed: D00Z (zeros) & DOOZ
The float is available by itself .The float is made of two pieces of brass soldered together. Solder breaks down, gas seeps in, float settles to the bottom of the tank.
COAZ-9202-B .. Fuel Sending Unit Float - Available from Ford .. It's also reproduced in plastic by Carpenter .. Ford dealers have dozens in stock
1957/70 ALL FoMoCo vehicles.
