leak below egr
Old Nov 3, 2003 | 12:51 PM
thesupe's Avatar
thesupe
leak below egr
I recently replaced the gaskets at my valve covers and efi ina 351w 89 Ford after doing this i have a leak at what appears to be the pipe protruding from the bottom of the EGR is this possibble. It smells like coolant. If I happened to rupture this pipe is it easy to replace it at autozone parts or other parts store.
Old Nov 3, 2003 | 02:21 PM
MunsterGarage's Avatar
MunsterGarage
where does the pipe go to, manifold? Or is it a coolant line?
Old Nov 3, 2003 | 02:53 PM
thesupe's Avatar
thesupe
this is a metal pipe that runs to the exhaust manifold. It is covered with braided fabric but im sure there is a metal line inside.
Old Nov 3, 2003 | 04:06 PM
MunsterGarage
there isnt coolant in that tubing...just replaced that manifold on mine 2 weeks ago....do you see any coolant? and where.
Old Nov 3, 2003 | 04:28 PM
thesupe's Avatar
thesupe
yeah there is coolant all over the braided fabric on the egr line
Old Nov 3, 2003 | 05:03 PM
MunsterGarage
check the 2 heater hoses that run accrss that way..you might have a tiny leak thats spraying down on it. any possible way to email some pics of this?
Old Nov 4, 2003 | 10:19 AM
DanTana's Avatar
DanTana
On my 88 351 there is a small coolant line that runs to the top front passenger side of the throttle body. It's possible that is leaking or maybe there is a crack that is allowing that coolant down the EGR pipe?
Old Nov 4, 2003 | 05:45 PM
thesupe's Avatar
thesupe
think i found the leak. Thanks guys
