much easier!
Old Oct 17, 2021 | 07:50 PM
jcnorton's Avatar
jcnorton
much easier!
I followed suggestions/ideas from a couple of sources and changed my front axle grease on the 14 F150 by drill, drain and tap method. was easy. worst part was right as I was ready to start the project and laying out tools was the realization that the brass plug I bought {would have preferred steel but none local} was a odd size at 7mm which I didn't have and couldn't find local {allen wrench} finally pilfered one from my boy and all went well. kind of a switch me pilfering tools from him!
Old Oct 17, 2021 | 08:48 PM
catequipment's Avatar
catequipment
So you just drill and tapped it for a drain plug? I like that idea. I need to do them on my ‘13. I may try this. Would it work on the rear also?
Old Oct 18, 2021 | 08:05 AM
BassFantasizer's Avatar
BassFantasizer
It's always an odd feeling when you pilfer tools from your kid, until it hits you that you "pilfered tools from your kid" and it turns to pride.
Old Oct 18, 2021 | 08:22 AM
jcnorton's Avatar
jcnorton
it would work on the rear but a little different animal being cast iron. to me it's easy enough to drop cover. it's well worth it to be able to clean it out and look things over. the front end gets so much less use {on most} that I'm willing to fore go the cleaning and inspection. Jim
Old Oct 18, 2021 | 08:59 AM
catequipment
Makes sense. I may try it
Old Oct 21, 2021 | 10:39 AM
Brankon's Avatar
Brankon
Do you have a link to other forums that suggested this?
Might be a handy mod for the future for me
JaySVX
May 21, 2025 11:40 AM
union_guy
Mar 29, 2021 03:21 PM
nmclella
Apr 3, 2015 07:19 AM
ROBBINthaHOOD
Nov 21, 2011 03:41 PM
Barely Smokin'
22
Jan 9, 2010 02:33 PM
