Pistons for 226
Old Oct 12, 2021 | 05:40 PM
myretirementproject1949F1's Avatar
4wd Low
Pistons for 226
Good Afternoon rebuilding my 6 cylinder 226 any good leads on pistons? Looking like hens teeth. Found Egge Anybody else maybe less than 50.00 per piston? Thank you Jim
Old Oct 12, 2021 | 07:11 PM
pineconeford's Avatar
pineconeford
Knuckle Bandage Sales Rep
Hi Jim,
Check on E-Bay periodically. They do show up there. Tonight there is only one standard size one available at less than $50. And three that are 0.030" over. A full set of six is on there too, but they far exceed your price wish.
Parts show up every day on there. Might not take long to find some. Do you want standard size or over? Maybe a member here has a lead on them.
Tom
Old Oct 13, 2021 | 12:18 AM
Scotty's 52 F3's Avatar
Scotty's 52 F3
If you find no luck here, might be worth a look over at Ford Barn. A lot of guys over there with "stashes" of parts.
Old Oct 13, 2021 | 05:58 AM
Marauder2004's Avatar
Marauder2004
I think I still have some. Are you looking for standard or oversize?
Old Oct 13, 2021 | 11:56 AM
4wd Low
Thank you for the leads, I am still working the block thinking .020 to .030 over I have one scar in number six hole and once I get the final dimension I will be back with you . Marauder 2004 thanks for letting me know you have some. Jim
Old Oct 16, 2021 | 10:48 AM
38 coupe's Avatar
38 coupe
One other good trick is to get the original factory part number and google search for it. I found a set of NOS +0.030 pistons for my 215 at about a third of Egge's price. You may want to determine minimum oversize, find pistons that size or larger, then final bore for the pistons you buy.
Base part number: 7HA-6108 Suffix notes oversize: -A = std., -B = +0.0025, -C = +0.005, -D = +0.020, -E = +0.030, -F = +0.040, -G = +0.060
Base part number: 0HA-6108 Suffix notes oversize: -A = std., -B = +0.0025, -C = +0.020, -D = +0.030, -E = +0.040, -F = +0.060
Old Oct 16, 2021 | 11:00 AM
52 Merc's Avatar
52 Merc
Like these...?
https://www.ebay.com/itm/154172983739
Please save the boxes for me. Thanks.
thomgcfour
Dec 7, 2012 06:20 PM
TMI
Jun 2, 2005 08:23 PM
