Axle Spreadsheet
Old Oct 12, 2021 | 04:29 PM
Phoenixfla's Avatar
Phoenixfla
Axle Spreadsheet
I re-created the Axle Availability Spreadsheet from the 2022 Order Guide in a Google Sheet. I am trying to identify each Brand and Model of axle for each available combination. I was able to get some info from the Axle Recall Thread, and filled in if the Axle was a Sterling 10.5", Dana 275 or Dana 300. If anyone has the missing data, please let me know. Specifically, I am missing most of the F-350 SRWs. If you see anything that is incorrect, let me know that also.
Thanks!
2022 Super Duty Axle Availability
Old Oct 12, 2021 | 04:56 PM
CR250Bronco's Avatar
CR250Bronco
I think you get the Dana 275 on the 250 if you order the 4.30
Old Oct 12, 2021 | 05:29 PM
h20camper's Avatar
h20camper
Nice job. Might want to add some additional verbiage for cells:
  • E4 - Optional DANA 275 - (Requires...
  • D7 -Standard - Dana 275
  • F8 - Standard STERLING 10.5
  • F9 - Standard STERLING 10.5
  • E13 - Standard DANA 300
  • K7 - Optional DANA 275
  • L7 - Optional DANA 275 (Standard w/ Tremor 17Y)
  • M9 - Optional STERLING 10.5
  • N9 - Optional STERLING 10.5
Double check my work though.
Old Oct 12, 2021 | 05:44 PM
Phoenixfla's Avatar
Phoenixfla
Thanks, I've added all those.
To everyone please let me know if you find any incorrect information. And don't rely on it for any important decisions!
Old Mar 12, 2022 | 02:12 PM
thestoicmarcusaurelius's Avatar
^^^^^^^^^ great chart !!!
what's the difference between the "optional" sterling 10.5 and the standard sterling 10.5?
also, i just switched my order from a 250 with 7.3 with 4.30 gears to a 6.7 with 3.55 elocking rear axle
does anyone think it's worth going to HCTT or the 350 to go to the Dana m275 instead of the sterling 10.5?
Old Mar 12, 2022 | 05:10 PM
h20camper's Avatar
h20camper
The optional is getting the locker.
...does anyone think it's worth going to HCTT or the 350 to go to the Dana m275 instead of the sterling 10.5?
I'd say no as Dana has had quality issues of late.
Old Feb 13, 2023 | 05:23 PM
fl0w3n's Avatar
fl0w3n
4wd High
FYI, my 2021 F250 6.7 Tremor package with 10,800# GVWR package has the M275
Old Feb 13, 2023 | 06:00 PM
RidgwaySD's Avatar
RidgwaySD
I thought all of the diesels since 2020 used the M275, 250 or 350, the Sterling reserved for gas models?
Old Feb 13, 2023 | 09:23 PM
IADiver's Avatar
IADiver
Nope, my 6.7 250 has Sterling, which I am good with.
Old Feb 13, 2023 | 09:30 PM
chadstickpoindexter's Avatar
chadstickpoindexter
Yeah, the only way to get the Dana on a 250 is to add the HCTT package with the diesel engine, or go with 4.30’s on the gas engine. At least on the 22MY’s anyway…
Old Apr 30, 2023 | 10:19 AM
leadmic's Avatar
leadmic
I have a 2022 F250 TREMOR with an M4 Dana M275 4.30 E-locker and a 7.3L gas motor.
Old Apr 30, 2023 | 10:44 AM
Silverback3's Avatar
Silverback3
4wd Low
My 22 F250 XL with 7.3 and 4:30 has the M275.
Old Sep 20, 2023 | 08:24 PM
pauliwalnuts's Avatar
pauliwalnuts
Does anyone know what the GAWR are for both axles on both the F250 and F350? Are the GAWR different for diifferent axle ratios?
Old Sep 20, 2023 | 08:39 PM
4wd6.7L's Avatar
4wd6.7L
The highest rear GAWR on a 250 is 6340 no matter which axle it has. The SRW 350 can have up to 7230. Lower numbers seem to be influenced more by options than axle type or ratio.
Old Sep 21, 2023 | 03:11 PM
pauliwalnuts
Yea those ratings appear to be related to tire limitations, I am more curious about the axle itself independent of any options. Appears to be at least 7230 based on the 350 rating.
