Proper 6.0 Break in
Old Nov 3, 2003 | 06:39 AM
bigfoot4iwov's Avatar
bigfoot4iwov
Proper 6.0 Break in
Hi Everyone!
Just curious, I ordered my 6.0 (my first non gas vehicle). Is there any special breakin rules for this, or is it pretty much get in and drive?
Old Nov 3, 2003 | 06:42 AM
ALASKAF250's Avatar
ALASKAF250
I think no towing for first 1000 miles... Or keep your foot in it till you go get the new flash...joking
Old Nov 3, 2003 | 10:53 AM
BobJonesSpecial's Avatar
BobJonesSpecial
There is realy only one part that you can have any real effect on, and that is the piston rings. They will run slightly hotter on a brand new engine than they will after a few thousand miles due to the fact that they (the rings) are knocking down the slight cylinder imperfections left from manufacturing.
I would encourage as little lugging as possible or hard sustained pulling for the first 1000 miles or so. If you have to climb a mountain pass for example, do it but in a lower gear than you mught otherwise later on.
A lot of decelerating using engine braking is also good for engine break-in because it allows the rings to stay cooler and 'sucks' more oil up on to the rings to keep them cool.
BobJonesSpecial
