Driveshaft help?
Old Oct 10, 2021 | 04:45 PM
mwoj's Avatar
mwoj
Driveshaft help?
Hi all, I need to replace the rear driveshaft on my 1976 F250 4x4. The truck has a 390, NP435, and divorced NP205. I don't have my truck with me so I am unable to measure u-joint to u-joint. If anyone can help that would be great. I'm looking to order one so I can install it right away next time I have access to my truck.
Old Oct 11, 2021 | 01:20 AM
redroad's Avatar
redroad
This is what I have for you so far. I'll work on it some more tomorrow and post it here. The rear shaft according to the MPC is type 4 and 36 3/8 " long and OD is 2 1/2"
Note : Type 4 is u-joint to spline end.
The length of front and rear drive shafts were the same in all transmission types (np435, T18, and C-6) in the 1976 F-250 4wd 133" wheel base (highboy)
Old Oct 11, 2021 | 10:18 AM
440 sixpack's Avatar
440 sixpack
My '76 high boy rear shaft is 40 3/4" . stock suspension measured center to center on the caps.
Old Oct 11, 2021 | 01:11 PM
redroad's Avatar
redroad
I have two 76' highboy chassis up on the front of the property I'll walk up later to confirm. I must admit I'm still getting used to this MPC but I'm curious as to the discrepancy. The MPC is showing the rear shaft as having one spline end as in Type 4 above in the diagram is that what you have for the rear shaft?
Old Oct 11, 2021 | 01:52 PM
440 sixpack
yes it's type 4. there's no slip in the transfer case so it has the slip yoke on the driveshaft.
Old Oct 11, 2021 | 01:59 PM
redroad's Avatar
redroad
Got it So your 40 3/4" length includes the slip yoke then, right?
Old Oct 11, 2021 | 02:38 PM
440 sixpack
Yes. that's installed ready to run.
Old Oct 16, 2021 | 10:31 PM
mwoj's Avatar
mwoj
Thanks guys! This site never fails. I’ll see if I can find one to order.
blazedg
Escape & Escape Hybrid
Dec 1, 2019 12:19 PM
Ford_Six
Nov 25, 2008 06:36 PM
redteamgo2000
Oct 28, 2008 10:53 PM
steinbronn
Iowa Chapter
Jul 28, 2007 10:59 AM
51dueller
Oct 15, 2004 12:09 PM
