Engine Swap
Old Nov 3, 2003 | 01:09 AM
Cm snipe's Avatar
Cm snipe
Engine Swap
Hello im kinda new here but i have a question. Currently i have a 96 Explorer Xlt with control trac 4x4 4 door..i work with a guy is has a 98 Mustang GT with the 4.6L with auto tranny.is it possible to take his 4.6L an throw it in my explorer.Would i have to buy a new rearend/axle???im lost but im basically gonna get his setup for extremely dirt cheap.hes replacing his setup with a '03 cobra setup.
Old Feb 10, 2004 | 10:31 AM
GizmosStang's Avatar
GizmosStang
Axle in Ranger will be just fine it should either be ford 7.5 or 8.8, which were both used in the early 80 5.0 Stangs without major issues especially behind a stock motor...
Tranny/Transfer case will be you biggest issue, buy manual on both vehicles look extensively at the transmission wiring both should be Electronic Versions of the AOD and should not have many differences, Check pattern on 4.6 and 4.0 for the bell housing that might be your only concern...
You will require all electronics off the mustang, so if he isn't pulling them from the '03 setup he intends to use, I'd pass on it and find a donor car as you are looking $$$$$'s to buy parts seperately
Old Feb 11, 2004 | 04:22 PM
AlfredB1979's Avatar
AlfredB1979
96 Exploder/Ranger platform was not made for a 4.6L, so it won't fit when everything is hooked up to it.
Try a 5.0L from 96-02 Exploder and you're set. You need the tranny among other things, though, but should bolt right in.
Just because you get a cheap engine doesn't mean the install is possible/cheap!
Old Mar 23, 2004 | 02:06 AM
kevinhaddock's Avatar
kevinhaddock
5.0 in a 1992 explorer
Would that 96-02 5.0l v8 and tranny also bolt right into a 1992 explorer?
wpiccian
1997 - 2003 F150
29
Oct 7, 2024 05:44 PM
Big Daddy 18C
Oct 8, 2010 11:31 AM
jpuck99
1997 - 2003 F150
Sep 10, 2007 10:19 PM
JerNla
General Automotive Discussion
29
Jan 6, 2005 06:39 AM
L2R
1997 - 2003 F150
Jan 21, 2002 03:02 PM
