Intellitronix Digital Dash
Old Oct 9, 2021 | 01:18 PM
MrDormouse's Avatar
MrDormouse
Hello. Have the Dash for a 1984 Ford F150, 302, 2wd Auto. The Water Temp the sensor Intellitronix requires has two wires (Blue & Black w/ blue). The digital dash only has one (blue). If the sensor grounds through the threads, as stated in the instructions (and that's all it states) am I also supposed to ground with one of those sensor wires? If so, which (assume blk w/ blu so the plain Blue would match the dash plain blue). Please advise. Thank you.
Old Oct 9, 2021 | 02:41 PM
Mustangtc65's Avatar
Mustangtc65
Trailering
On their site under support, you can fine the instruction to the install of the sensor only. They offer a few so look for the one you have. I have some of there individual gauges and the oil sensor did have a ground wire.
Old Oct 9, 2021 | 03:30 PM
MrDormouse's Avatar
MrDormouse
I went for it and attached the blue to blue on dash and grounded the blk w/blue stripe and it seems to work.
My fuel gauge is still not reading though :/ I attached the dash wire to the yellow/wht that was to the Pin assembly #11 but not working. ugh.
Voltage looks good. RPM just keeps flashing 8cyl and then 6000 even if I rev in Park. It's auto though and I connected to the Grn wire that came from the previous aftermarket tach (I don't know if that ever worked though).
scottddove
Feb 26, 2008 12:34 PM
oem78
Jun 3, 2006 01:33 PM
Kirk
Mar 18, 2004 08:01 AM
