Dash removal
Old Nov 2, 2003 | 11:38 PM
RubberDuck's Avatar
RubberDuck
Dash removal
How do I get the black plastic piece around the gauge cluster off? It's a 96 F350. I thought it popped off, but it didn't seem to budge and I don't want to break it. Thanks
RubberDuck
Old Nov 3, 2003 | 12:10 AM
aikigod's Avatar
aikigod
You need to pry the strips of plastic trim moulding off the dash; there should be four Torx bolts holding the black trim piece on. Remove the bolts and you should be able to wiggle the piece off.
Old Nov 3, 2003 | 03:40 AM
RubberDuck's Avatar
RubberDuck
Forgive me this may sound dumb, but what plastic strips? I'm not following.
RubberDuck
Old Nov 3, 2003 | 07:10 AM
larry derouin's Avatar
larry derouin
The HORIZONTAL strips(They should be a very dark gray) below the light switch on the left and the blank panel on the right of the column. Just pry them out and then you have 4 TORX screws to contend with. Once they are out then just "WIGGLE" the Dash cover off.
Old Nov 3, 2003 | 08:46 AM
RubberDuck's Avatar
RubberDuck
Now, I got it. My strips are actually black and matches the piece that you wiggle out. I always thought it was one piece. Thanks a million for the info guys.
RubberDuck
RubberDuck
Sep 11, 2006 10:23 PM
RubberDuck
Oct 18, 2005 08:28 PM
RubberDuck
Jan 22, 2005 02:16 PM
RubberDuck
Sep 11, 2004 04:24 AM
RubberDuck
20
Feb 2, 2004 08:23 AM
