Fuel Injectors????????????
Old Jun 26, 2000 | 08:58 AM
oldogy's Avatar
oldogy
Looking at, to possibly buy, a 1990 F350 with 460 in front of an E4OD. The truck has an intermittant "miss" under load. The easy stuff has been done, plugs, wires, cap, rotor, filters. The truck sets no code. Any way to tell which injector it is? Any other ideas? At $90. per injector I do not want to go changing them out just to troubleshoot. thanks in advance. woof
Old Jun 26, 2000 | 10:24 AM
PAUL_2's Avatar
PAUL_2
I doubt its one of the injectors , usually when an injector dies , it dies and I have seen very few defective ones . When does the miss occur , at what temperatures, rpm's , can you duplicate it on demand or is it random ? Fuel pressures is one place to start , check the pressures from cold start to operating temp , also if the TFI module has never been replaced it may be causing the miss . Wiggle test all connectors and the engine wiring harness during idle to see if you can duplicate it . My 90 F150 300 has had an intermittent miss since Ive owned it , its so sporadic and random I gave up looking for it yrs ago . The only thing left that I havent inspected is the EEC . The truck runs fine otherwise . I suspect under the right conditions the EEC cant process the all the inputs it gets and momentarily dies ?
Paul
Old Jul 2, 2000 | 02:29 PM
oldogy's Avatar
oldogy
Thanks for the reply, Paul. I bought the truck and the after checking it out decided it was probably universal joints causing the vibration and "miss" or hesitation. Sure enough, one of the u joints was freezing up pretty bad. Replaced them all and the truck runs smoothly.
Old Jul 2, 2000 | 10:37 PM
djackson's Avatar
djackson
