86 valve cover?
Old Oct 7, 2021 | 10:31 AM
FrankTheMechanic's Avatar
FrankTheMechanic
86 valve cover?
This probably belongs in the marketplace...but since it's 300L6 I hope to get away with asking.
I just completed the install of a new(er) engine in my '84 F150, and the donor engine came from an '86. I REALLY like the valve cover-it's got the PVC fitting at the rear, a PVC hose fitting at the front, and an oil filler at the very front. Trouble is, it's pretty rusty-as was the whole engine when I got it.
Anyone have another valve cover in nice shape they'd part with?
And yes, the new(er) engine runs great. I replaced main/rod bearings, oil pump/pickup screen, installed a Schneider cam and lifters, Cloyes timing set, every gasket and seal, clutch/flywheel, damper...It's much better than the old one.
Old Oct 7, 2021 | 05:20 PM
The Frenchtown Flyer's Avatar
Be aware that the EFI valve covers use smaller metric bolts and thus the cover will need drilling to use on your earlier carbed head, as will the silicone gasket.
Positive Crankcase Ventilation = PCV
Polyvinyl Chloride = PVC.
Old Oct 8, 2021 | 08:49 AM
FrankTheMechanic
The one from the '86 engine use smaller, 7/16" bolts (or that's the size of socket I used to install the VC) and after I ground off the little **** on the sealing surface, the silicone gasket fit perfectly. Not sure why it worked but it did. Maybe someone swapped out the head at some point?
Sure runs good, though.
I CAN use the VC I have, but if I can get a nice one, I will.
Thanks for the info, FTF.
Old Oct 11, 2021 | 05:40 AM
arse_sidewards's Avatar
arse_sidewards
I'm 99.9% sure my EFI heads are all 1/4-20
Old Oct 11, 2021 | 07:49 AM
'86 and earlier heads have 5/16" bolt holes.
Old Oct 11, 2021 | 02:44 PM
FrankTheMechanic
Oh, bother. I didn't even notice your correction the first time around.
Thanks, FTF.
Old Oct 11, 2021 | 02:45 PM
FrankTheMechanic
Makes me wonder if someone swapped an EFI head on this engine block. Would it run well if it had been ?
stonfelo
Mar 7, 2010 07:45 AM
83maverickf-100
May 26, 2008 09:15 PM
xpres
1983 - 2012 Ranger & B-Series
Oct 12, 2004 10:32 AM
mrmrschris
Jul 22, 2003 11:38 AM
wsweat40
Apr 19, 2002 07:36 PM
