Fuel Injection Newbie
Old Oct 5, 2021 | 07:32 PM
Grum894x4's Avatar
Grum894x4
I have been the proud owner of this 1989 F250 4x4 Super Cab with a 460, for 21 years. I’ve replaced the driver’s side front hub, the occasional u-joint and even the steering gear, but I’ve run up on an issue and I’m at a loss.
I went to the local parts house a few weeks ago in my truck, pulled up, shut it off, and it hasn’t hit a lick since. The fellas at the store were kind, but useless.
After many vain attempts at starting it, I figured it had to be fire or fuel, so I sprayed the slightest bit of ether into the air intake. It hit, but just for a millisecond, so I guessed fire wasn’t the issue. Since then I’ve replaced the in tank fuel pickup assembly with new pump, filter, float and sending unit. Replaced the inline fuel filter and high pressure fuel pump, AND the fuel pressure regulator.
Still won’t start.
I finally put a pressure checker on the injector rail(which I feel sure now, I should have done in the first place), when the key is in on I’ve got no pressure, but when I turn the engine over, I’ve got about 41-42 psi.
Any ideas or thoughts would surely be appreciated.
Old Oct 5, 2021 | 07:43 PM
My4Fordtrucks's Avatar
My4Fordtrucks
So the in tank pump does or does not run for a couple seconds when you turn the key to “RUN”?
Old Oct 5, 2021 | 08:09 PM
Grum894x4's Avatar
Grum894x4
It runs constantly. I even went so far as to take the return line off when I put it in, just to make sure it was pumping.
Old Oct 5, 2021 | 08:51 PM
Puddy's Avatar
Puddy
Honestly it’s starting to sound like the EEC is starting to bite the biscuit.
Old Oct 5, 2021 | 09:05 PM
rla2005's Avatar
rla2005
Originally Posted by Grum894x4
It runs constantly.
Very common symptom of a bad computer. Dozens or more threads in this forum with the same symptom and root cause.
Old Oct 6, 2021 | 03:51 AM
My4Fordtrucks
It runs constantly.
That is not good. It should shut off after priming the system. I agree with the others that the computer died. I’ve seen that in person.
Old Oct 6, 2021 | 11:40 AM
wwhite's Avatar
wwhite
Pull out the ECU/PCM EEC, have a look at pins for corrosion(white grease is normal), open it up, look for bad, corroded, leaky, anything that doesn't look right.
If it looks good, problem 'could' be elsewhere.
If it looks bad, figure out if can be fixed or not.
Old Oct 12, 2021 | 06:26 PM
Grum894x4's Avatar
Grum894x4
Well, work kept me from it for a bit, but I finally removed the ECM. Did a visual inside and out and it is a bit rough looking, but nothing really noticeable. So while trying to decide what was next, I took a small wire brush and cleaned off the pins, put some dielectric grease on the pins and plugged it back in, just to see. Oddly enough, it started right up. I tried it three more times, the first time it stuttered and started, the second time it just stuttered, and the last time it never hit.
Thoughts?
Old Oct 13, 2021 | 01:19 PM
rla2005's Avatar
rla2005
Could be a short lived victory IMHO. Without a photo of the inside it is anyone's guess if your efforts paid off in the long run.
Old Oct 13, 2021 | 01:53 PM
Grum894x4's Avatar
Grum894x4
I went ahead and ordered a refurb. I was just thinking that probably points to it being the underlying issue.
Old Oct 15, 2021 | 07:52 PM
Grum894x4's Avatar
Grum894x4
Success!!!(so far, anyway)
Thanks for all the assistance.
I was pretty much at the end of my rope.
Old Oct 16, 2021 | 07:25 AM
rla2005's Avatar
rla2005
Glad you got this one whipped! Also thank you for replying back.
Old Jan 21, 2022 | 03:24 PM
Grum894x4's Avatar
Grum894x4
It’s me again.
Well it’s been about three months and besides just a couple of little hiccups, the truck has started every time, until today.
It’s not a daily driver, so I haven’t really put it to the test, but when I tried it today, it’s a no go.
Any thoughts on what might be eating the ECM?
The refurb was from rock auto and seemed fine, and was, for three months.
Old Jan 21, 2022 | 03:50 PM
rla2005's Avatar
rla2005
Same symptoms as before? I cast a leery eye at these refurb'ed PCM these days. Have you started back at the basics again? Fuel and spark, etc.
Old Jan 21, 2022 | 11:26 PM
Grum894x4's Avatar
Grum894x4
I haven’t been too thorough yet. Between the snow, the cold, and the utter frustration, I’ve been slow to act. It’s supposed to warm up on Sunday so I’ll probably give it a look then.
I went so far as to go to a shop today for a little help, but they don’t work on anything later than a 95. I should probably throw in the towel, but I just can’t.
