Best balancing beads
Old Oct 9, 2021 | 10:13 PM
morehouse7's Avatar
morehouse7
Originally Posted by Buckeye71
Can you use centramatic on SRW?
Yes sir, seems they are more popular with DRW though.
Old Oct 10, 2021 | 03:30 PM
porthole's Avatar
porthole
Originally Posted by cpro24
When u add the centramatics do u leave the wheel weights on and it fine tunes the balance or do u remove the wheel weights all together?
Balance Masters which are similar to the Centramatics state in the instructions to remove the weights.
And on a 450 they are a pain to remove. Wheel weight pliers don't work, I used two different seal pullers.
Old Oct 10, 2021 | 03:58 PM
nuctrooper's Avatar
nuctrooper
On a 450, just jack it up and let the air out of the tires. Tire falls off the bead. Then the weights just peel right off super easy. A clamp on air chuck is a must (or a helper) as you may have to kick or jostle the tire to get the beads set enough to hold air. Or use a heavy ratchet strap around the circumference and tighten it down as much as you can- that will force the beads out onto the rim. Just be sure that as soon as you get a couple pounds of air in the tire to remove the strap.
crazyredneckanyhow
Offroad & 4x4
Aug 20, 2019 03:05 PM
texasdynarider
Feb 4, 2012 03:18 PM
HD74
24
Apr 25, 2009 01:44 AM
Bender99
Offroad & 4x4
Apr 21, 2009 12:48 AM
homesteader
Sep 27, 2007 11:17 AM
