Compression Question
Old Oct 3, 2021 | 12:37 PM
Zombie Builder's Avatar
Zombie Builder
Back in the 70s I built my share of engines
I am 62 now and thought I would restore am old truck.
I now own a really clean 69 F-100 360
I need to decide to ether build a motor or use this one
I know nothing about the truck except the motor is clean like it was just rebuild. Really clean!
Pulled the PCV valve and no blow-by Sounds good when it is running but an exhaust leak makes me not want to run it much
Pulled the plugs and they all are a nice toasty brown and no signs of oil
Compression, throttle wide open,,, test #1 and #3 are 100psi dry but #5 is 80 dry and 95 wet, #7 is 45 dry 60 wet
I checked the rockers to see if maybe the intake wasn't opening Everything looked good on a dial indicator
Why are the plugs so nice looking if it has bad rings? Plus no blow by
Do you think the exhaust manifold leak trashed a valve or actually the exhaust valve in 2 cylinders dropping the compression?
I drove it home 15 miles with the leak
If I totally rebuild the motor, plus rebuild the rest of this truck, I will never sell it for what I have in it
Not planning on selling it but you never know
I am into any input before I decide my next move
Old Oct 3, 2021 | 03:11 PM
Christmas's Avatar
Christmas
Welcome to FTE. Compression is too low. How about some pics of the truck.
Old Oct 3, 2021 | 04:22 PM
motogotor's Avatar
motogotor
I don't think the compression came up enough between the wet and dry test to be bad rings. Also, oil rings and compression rings are separate on most engines so the compression rings could be worn and the oil rings be fine.
#5 and #7 are side by side so you could have a blown head gasket between the two?
Old Oct 3, 2021 | 04:35 PM
bushuna's Avatar
bushuna
Pretty sure #6 is between #5 and #7
Old Oct 3, 2021 | 04:43 PM
motogotor's Avatar
motogotor
You're right, I was thinking even on one side and odd on the other like Chevy but that's not right for Ford.
Old Oct 3, 2021 | 04:51 PM
bushuna's Avatar
bushuna
No problem. I hate to admt it on this forum, but I have a few G.M.'s in my past too!
Old Oct 3, 2021 | 05:29 PM
Lrrr-RulerOfOmicronP's Avatar
I would run a leak down test and see how that goes.
Old Oct 3, 2021 | 07:57 PM
351Cleveland C4's Avatar
351Cleveland C4
If it runs good, run it!
If you're looking for performance, I'd pull it and build it. Turn it into a 390 or 410 with 10:1 and a moderate cam. You'd easily be at 400hp then.
Old Oct 3, 2021 | 08:03 PM
'65Ford's Avatar
'65Ford
Money wise, I don't think it's possible to get out the money you put into a classic car/truck...it's kinda like being in love...
My strategy was to get a properly built motor for the smiles per gallon...
Old Oct 4, 2021 | 11:16 AM
Zombie Builder
My first mistake was to assume the cylinders were odd on the right and even on the left. If it is 1-4 on the left and 5-8 on the right.... My problem I saw so far is #7 and #8
Motogotor - I think you have a made a good point. It could be a blown head gasket. I did not test the other side because I figured it was a bad motor. Today I will check the other 4 cylinders so I can be sure it is just the 2 that are side by side
I assumed that I should get 110psi or greater so I felt like none of them checked great. I also assumed the exhaust leak warped the exhaust valve
With the short stroke of the 360 (3.5") compared to the 390 having the longer stroke (3.750"), would the compression be closer to 100psi???
I dont have a leak down tester and I am not sure what i would learn by testing "leak down" If it cant build more than 50 psi it must be leaking somewhere... Right?
It doesnt have any rust or bondo. It has new duel exhaust and new radiator, everything works. 3 on the tree that I will put on the floor later
Slack in the manual steering and original style manual brakes
Old Oct 4, 2021 | 11:21 AM
Zombie Builder
No blow by coming out of the valve covers makes great sense if the valve is warped or the head gasket is blown
About to go out and test the left side
Old Oct 4, 2021 | 11:25 AM
Christmas's Avatar
Christmas
Cylinder numbers are on the intake manifold.
Old Oct 4, 2021 | 11:31 AM
Zombie Builder
So on a 360 what should the compression be on a good or usable cylinder?
Old Oct 4, 2021 | 11:49 AM
pressurizing the cylinder can tell you where your leak is at. You can look for where the escaping air is going like exhaust, out the carb, crank case or cooling system.
Old Oct 4, 2021 | 11:59 AM
Zombie Builder
That is exactly what I need to do. Not leak down but hook it to a compressor and listen to where it is leaking
Great idea Thanks!!!!
I looks like all the shortages will make it near impossible to buy a long block I has 2 companies tell me if I placed the order it could be over 6 months to get a motor
