engine wont turn off
Old Nov 2, 2003 | 08:27 PM
hvan's Avatar
hvan
I have an '85 E350 381 5.0L with some apparent eletrical problems. With the key out of the ignition there is a current draw and the battery will go dead overnight. Also, after being started the engine continues to run after the ignition switch is turned off and key removed. I have replaced the ignition switch / key lock assembly with no success. The starter, solenoid, duraspark unit, alternator, and regulator have all been replaced for other reasons. Any guidance on where I should start looking would be appreciated.
Old Nov 3, 2003 | 08:59 PM
locknkey's Avatar
locknkey
EFI or Carb?
Old Nov 4, 2003 | 09:13 PM
hvan's Avatar
hvan
it has a carburetor, sorry for the ambiguity.
Old Nov 5, 2003 | 02:39 PM
locknkey's Avatar
locknkey
The switch under the steering column could be your problem...it provides current to your ignition mod.
Old Nov 8, 2003 | 09:28 PM
steve83's Avatar
steve83
Does it have a tilt column? The actuator could be broken. It's a $20 part from Ford, but takes a couple of hours to disassemble the column & install.
Old Nov 11, 2003 | 09:05 AM
95se5m's Avatar
95se5m
Does anyone have a step-by-step on replacing this? I need to do that this week so I can get my baby back on the road...
Help please?
