Powertrain Control Module
Old Nov 2, 2003 | 07:47 PM
EK082's Avatar
EK082
Have a 98 Explorer 4.0l. Was wondering what this module does and if it is defective can it cause a rough idle before the vehicle is shifted. I ask this because when I start my truck it idles rough, but if I put the truck in neutral, reverse, neutral, then drive the rough idle disappears. ?????????????????????????????????????
Old Nov 2, 2003 | 09:01 PM
FortyFords's Avatar
FortyFords
The pcm is the brain an uses all its sensors to controll timing and fuel mixture
could it go bad, yeah!, problably but not likely!
rough ilde without a cel light on in the dash is usually a dirty or bad IAC valve
It can be other things too .
I would get your car scanned for some DTC's
If you can't ,then start with normal tuneup things like
plugs
wires
air cleaners
pvc valve
Rich
Old Nov 2, 2003 | 11:02 PM
EK082's Avatar
EK082
Sorry didn't mean the PCM. I meant to say the Transmission Range Sensor (TR).
