1941 Pickup Firewall height
Old Sep 29, 2021 | 03:59 PM
Mike Sanders's Avatar
Mike Sanders
So, I am replacing my firewall and front cab panels. The cab corners because of rust and the firewall to fit my 390 big block. The only issue I have is that this truck had a lot of bodywork done to the cab before I got it, so I'm not sure of the actual dimensions when mating these pieces up. The most important one is setting the right height, then I believe the pieces will fall into position. So, does anyone have the distance from the top of the firewall to the bottom of the front cab support? The one on the outside front that the cab corners mate to? I say the bottom of that bracket and not to the frame because I think we might have different heights depending on what kind of cab supports someone used (wood, rubber, bushings, etc.). Thanks for any help!!!
Old Oct 18, 2021 | 02:05 PM
MyFlattyFord's Avatar
MyFlattyFord
Mike,
Would you have the wood pattern for mounting the cab onto the frame of your 41 pick up?
Thank you.
Marty c. # 773-four-nine-zero-9747
4EyedTurd
17
Mar 19, 2019 07:16 PM
hasteranger
24
Aug 19, 2013 11:36 PM
bwalt11
Jun 25, 2010 07:02 PM
Lwlandy
Oct 6, 2005 09:24 AM
