1990 e350 460 PCV valve
Old Sep 26, 2021 | 04:36 PM
jred151's Avatar
jred151
Does the top port on the PCV need to be hooked up anywhere?
thanks
Old Oct 2, 2021 | 11:05 PM
highest_vision's Avatar
highest_vision
I can't tell you if there should be anything connected there, often times a multiport PCV valve fits more than one application or the engine has different options of PCV valve for things like high altitude or federal/CA emissions. I can tell you that if there is no second hose, then that second port needs to be capped off.
Old Jul 17, 2025 | 08:36 PM
BigJuicyLucy91's Avatar
BigJuicyLucy91
4th Gear
I know this is old but did you ever figure out an answer to this? I’m wondering the same thing right now.
Old Jul 18, 2025 | 05:51 AM
manicmechanic007's Avatar
manicmechanic007
thanks
No, that top port was used on some applications back in the 80's
That is why now days, there isn't even a hole drilled in that top port
Just leave it
Back in the 80's when you bought one, it came with a manifold cap because the port was open
Old Jan 23, 2026 | 10:59 AM
Darro's Avatar
Darro
Trailering
thanks
THANK YOU!!!
rtcapo
Jul 27, 2021 08:12 AM
SoCalAngler
Mar 8, 2021 12:36 PM
jdq
2009 - 2014 F150
Feb 27, 2017 08:53 AM
mvlr5000
1983 - 2012 Ranger & B-Series
Jun 15, 2005 02:50 PM
sixcar
Jul 17, 2002 12:38 PM
