I have a 2007 XLT with 18” factory wheels. The tired being pretty worn and needing to be replace I found a newer set Ford factory wheels with almost brand new Hankook tires at a heck of a price so I grabbed them up. I was proud of the deal I had found but I soon found out I had a problem. Both my previous wheels and these newer ones(not sure of year model) have the same 6-bolt pattern however the hole diameter on the newer wheels is smaller than the old ones and the wheels won’t fit over my larger diameter 07’ lugs. Best and/or least costly remedy?
Welcome to FTE..Your question will be best answered in the, "Newer Light Duty Trucks" section. They are the experts.
For what it's worth, your 2007 has a 6 X 135mm pattern. This is the same pattern used on the 2021 F150. It is very likely, your wheel are for another brand of vehicle. Look on the inside/backside for a logo or brand name.
Don't forget to check out you Texas State Chapter of FTE too.
