squeel when starting
Try tightening your belt! If any fluids gets on it, you'll end up w/ this problem! Super clean pullys + replace belt if nothing else works!
____________________________________________
‘90 Ranger XLT: 2.3L, EEC-IV, EFI, DIS, 2wd, Mazda 5sp
Providing everythig is correct, and the bearings are in good shape, the most likely culprit is often a dirty pulley. To clean them without removing the belt, you can spray the belt (with the engine running) with a little WD-40 or similar product . . . . it doesn't take a lot, though it may need doing every time you start for a while.
What I did when I had this problem was start the engine, spray, and drive to where I was going. Squeals usually did not recur during the drive.
You may wish to spend time trying to figure out exactly which of the components pulleys is causing the sueal though - if the puley bearings have lost their seal, you could be dealing with minimal or hardened lube that only softens and lubes the bearings when the bearings warm through running.
An ounce of prevention can definately apply here.
The belts squeel when under no loading, but as soon as you apply gas and get the truck moving the squeeling goes away. That tells me that the belt is too loose and it takes engine loading to get the belt tight enough. Not to mention the tensioner pulley looks like skid-mark city and also sits crooked.
I'm new to this forum; looking for posts about a suspected A/C system water leak that lets the driver side floor get wet and came across this post.
Had the same initially intermittent squeal on start-up on my 91 XLT, 2.3L 5-speed. Started about a year ago. Got gradually worse, became more like an intermittent screech. Fooled with new belts, tension, checked A/C compressor bearing, etc, no dice.
Then one morning on the way to work, I noticed something not quite right about the guages. Hmmm, battery voltage good, oil pressure zero, water temp norm - Holy****Batman! ZERO OIL PRESSURE!?! About that time the engine started talking to me. Immediately pulled over, shut down, called for a tow.
It took a couple days for the local garage to get it in, but I pretty much new that the prognosis wasn't going to be good and had some time to look at options. To make a long story short, I went the new engine route with 141000 miles on the original.
While they were at it, I had the opportunity to look at the old engine innards. Turns out the main bearing was scored, and the oil intake screen was about plugged closed with some thick gunky stuff. Way too thick and gunky to be typical oil sludge. My understanding is the original oil pan gaskets on that vintage engine were installed with sealant and that it was very easy to get excess sealant squeezed into the engine interior when the oil pan was installed. I don't have any proof, but my theory is that over time, this excess sealant deteriorated or broke off, and got pulled onto the oil intake screen. Once the screen got enough gunk on it, the bearing started to suffer from oil starvation, and finally the oil pump could no longer pull enough oil through the screen resulting in engine failure. Could the intermittent squeal be from a suffering main bearing?
I would suggest an engine flush, but a flush probably wouldn't get this gunk out - The gunk will mostly get pushed around and then end up on the screen again. The only sure way to get it out would be to drop the oil pan and scrape the screen, and you about have to pull the engine to get the oil pan off.
Anyway, it was a learning experience. I have a new engine and clutch now (I figured after 141000 miles the original clutch might have some wear), a reconditioned radiator, and the ole twuck runs good as new again. No squeals.
Now if I can just fix that pesky water leak...
Gromit
91 Ranger XLT 2.3L 5-speed
Yes, I verified the dain is free. Pees like a drunk. I'm thinking I might have a crud dam built up somewhere, but I'm not sure what I need to tear into to look for it.
When I took the truck in for engine replacement (this just happened a couple weeks ago) the mechanic got on me for not using synthetic oil, thinking I had a sludge build up problem. Once he got it opened up and saw the gunk, he asked if I had been treating the oil with anything. Nope, straight dino oil, changed every 3k-5k miles. Not sure he believed me, but he concluded it wasn't typical oil sludge. I don't think he believed me either when I said the clutch was original at 141,000 miles. He said a flush would have cleared the screen but probably only have gotten some of the gunk out, and the rest would have ended back on the screen. Repeated flushes maybe would have cleared more of it.
I think it was old gasket sealant, and the mech allowed it could be. The new gaskets apparently don't go on with a separate sealant application anymore, so it shouldn't be a problem on the new engine. He didn't know when they went to the new gaskets.
Gromit
If the screech is from the main bearing starting to wear from oil starvation, an engine flush won't cure the screech. The only way to get rid of the screech is a new main bearing, if it really is the main bearing, which is pretty much a complete engine rebuild. But that's cheaper than a new engine if you let it go to complete oil starvation like I did. Checking all the belts and pulley bearings is cheaper yet than an engine rebuild, so do that first
The engine flush will just prolong the life of the engine, assuming it gets all the gunk off the screen and out of the engine. Problem is, it's tough to tell how effective the flush is without opening up the engine. If you see any fluctuation or twitching or anything unusual with the oil pressure gauge, I would most definitely try an engine flush, maybe even several repeated flushes.
Good luck. I got rid of my screech with a new engine, but that was a way expensive way to fix the screech. We'll see if I can't get it past 141000 miles this time.
Gromit
