Ac blowing through defrost
Old Sep 22, 2021 | 06:13 PM
teae7982's Avatar
teae7982
So pulled out of the driveway today and when I have my foot on the gas pedal it blows through the defrost when I help off and coast for a minute it comes back to the vents. Is this a vacuum leak and wear do I start looking.
Old Sep 22, 2021 | 06:18 PM
Dweber85rc's Avatar
Dweber85rc
Yes it is. If yours is a 4wd check the esof valve and lines, those are a common leak point.
Old Sep 22, 2021 | 09:46 PM
Vinny G-the EX man's Avatar
Vinny G-the EX man
The 4x4 solenoid is located on the passenger side fender just behind the battery, it cracks underneath and can cause the ac to default to the defroster. Exactly what happened to mine, 40 bucks later I was back in business. Good luck
Old Sep 23, 2021 | 05:31 AM
projectSHO89's Avatar
projectSHO89
ANY vacuum leak in the supply to the HVAC control head can cause this symptom. It's just that the PVH solenoid has become one of the more common failures over the years.
You can disconnect and cap off the solenoid's vacuum supply to isolate it from the rest of the vacuum distribution system to help diagnose.
Old Sep 27, 2021 | 09:25 PM
HorsePower Junkie's Avatar
HorsePower Junkie
I am having this same issue of hot air coming out of the dash vents all the time with the AC is on, on my 2WD F350.
Any suggestions?
Old Sep 28, 2021 | 05:58 AM
projectSHO89
Any suggestions?
Different problem.
Read the HVAC FAQs, see signature. for link.
Gambill
Jun 12, 2020 04:54 PM
oldcoupe42
Aug 14, 2016 07:39 AM
exiled
Aug 14, 2010 10:21 PM
BigRy
Oct 10, 2009 07:46 AM
ECA
Feb 26, 2008 06:58 PM
