Suggestions Needed
Old 09-22-2021, 05:15 PM
ynot321AB1's Avatar
ynot321AB1
ynot321AB1 is offline
Suggestions Needed
I am asking for any help available to get stuck valves out of the block,(239 flathead). I have tried blast it without success. I cannot get anything under the valve to force it up and a couple are up a short ways but not enough to get ahold of the shaft.
Old 09-22-2021, 06:37 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
Did you get the horseshoe clips off the guides? If so, the guides must have moved some, so hitting them with plenty of penetrating oil thru the ports may get them loose. If not, break out the torch...
Old 09-22-2021, 06:42 PM
ynot321AB1's Avatar
ynot321AB1
Nope
Haven't gotten the clips out even the ones that I have taken the valve out of. I rigged up my dent puller with a nail to create a hook for the clips and cannot get them to move.
Old 09-22-2021, 06:54 PM
ALBUQ F-1's Avatar
ALBUQ F-1
To get the clips out, you need a tool that pulls the guide down towards the cam. If the guides are stuck it will be tough. Is the engine out of the truck?
Old 09-22-2021, 07:32 PM
ynot321AB1's Avatar
ynot321AB1
Thanks
The engine is on an engine stand. I will try to pull the clips in a downward angle and see if that works.
Old 09-22-2021, 08:01 PM
49fordv8f4's Avatar
49fordv8f4
49fordv8f4 is offline
The clips are seated in a counter bored pocket, they will not come out unless the guide is moved down about 1/4" first. You can use a valve spring compressor and remove the spring keepers from the valve stem and pull the valves out, but the valve will have to be fully seated to use a spring compressor on it. The springs can be pryed out after the valve is removed, but it can damage the springs.
Mark
Russ74
32
02-18-2018 05:44 AM
joelowwatt
16
01-23-2016 09:03 AM
nando23510
11-15-2005 07:01 AM
bryanknie
Flathead V8 & Flathead 6
08-29-2002 09:52 PM
Quick Reply: Suggestions Needed
