Sponsored by: Real Truck
permanent rear diff oil
Old Sep 21, 2021 | 08:56 AM
zrone90's Avatar
zrone90
Went to get the rear diff oil changed on my 2015 F250 and the mechanic told me the oil from the factory is permanent and does not need to be changed. Is this true?
Old Sep 21, 2021 | 09:01 AM
Akley88's Avatar
Akley88
according to the owners manual rear fluid should be changed at 105k miles. page 464 in the link below
https://www.fordservicecontent.com/F...US_11_2014.pdf
Old Sep 21, 2021 | 09:02 AM
alloro's Avatar
alloro
If it's true it will say so in your owner's manual in the fluid capacities section.
Old Sep 21, 2021 | 09:19 AM
zrone90's Avatar
zrone90
I also check the manual first but truck is at shop and manual is in glove box. Thanks for the response.
Old Sep 21, 2021 | 09:24 AM
alloro's Avatar
alloro
You can download a PDF version of it here:
https://www.fleet.ford.com/parts-ser...owner-manuals/
Old Sep 21, 2021 | 09:37 AM
alloro's Avatar
alloro
I went and checked the PDF and here's your answer on page 461.
Old Sep 22, 2021 | 09:03 AM
senix's Avatar
senix
get another mechanic.
Old Sep 22, 2021 | 12:20 PM
masonlift's Avatar
masonlift
Read page 437 in your manual
Old Sep 22, 2021 | 12:27 PM
masonlift's Avatar
masonlift
Or page 464. End of schedule maintenance under exceptions. Lubed for life
Old Sep 22, 2021 | 12:44 PM
speakerfritz's Avatar
speakerfritz
its permanent until water from condensation that gets in thru the vent hose builds up.
Old Sep 22, 2021 | 12:47 PM
alloro's Avatar
alloro
DIY fluid change...$20...rear axle rebuild $2000...no brainer.
Old Sep 22, 2021 | 02:00 PM
Jimmy's Pilot Service's Avatar
Veteran: Navy
I know I have an older truck but cheap and easy compared to the rear end replacement or rebuild..
Do it every couple years, or if it gets dunked, or about 50,000 ish around an oil change cycle.
Well, Because..
Old Sep 23, 2021 | 11:42 AM
RigCity's Avatar
RigCity
Anything called lifetime is a lie….maintain the machine On my family members vehicle at 90 K the transmission fluid was black Of course I was told it’s lifetime and the mechanic told me to blah blah blah too bad his transmission went out 30k or so later
motor-man
Jul 13, 2011 04:58 PM
ghunt
Oct 22, 2009 10:52 AM
bryanlindborg600
Sep 7, 2009 06:17 AM
cowmilker08
Apr 29, 2009 10:06 AM
C350CREW
May 29, 2008 08:18 AM
