Computer Chips & Tuners
Diablo Chip programming
Old Nov 2, 2003 | 03:00 PM
HeavyAssault's Avatar
HeavyAssault
Question Diablo Chip programming
1. stock program
2. Premium Octane high performance program
3. custom program
Ok these are the programs that you will get with a 3 stage chip.
What I would like is to have a 87 octane performance program based on my mods and a 93 octane performance program based on my mods and a stock program that will work with my mods.
Is this possible?? I understand "stock" and "custom" but I want the stock settings that will take in account my mods for best performance using the stock setting.
Old Nov 2, 2003 | 03:36 PM
FTE Ken's Avatar
FTE Ken
What are your mods? Depending on that, it may be two customs instead of one.
Stock cannot be changed. Its the chip in the "off" position, whatever is in the stock computer is what runs when the chip is in the stock setting.
Old Nov 2, 2003 | 04:39 PM
HeavyAssault
ACCUFAB throttlebody, MAS, Headers, K&N FIPK, electric fans, Sonnex Valve/Tricummulator Springs.
I have a data sheet for the MAS. I do not want any tranny line pressure changes, I may change the RPM shift points.
Is it possible to run the chip with a PPIII setting installed?? So when I turn off the chip, I'm running using the PPIII settings??
Old Nov 8, 2003 | 10:40 PM
FTE Ken's Avatar
FTE Ken
Yes, the chip will work with the PPIII, overriding it when its switched on. All of these mods are fairly standard things we can program for. The data sheet for the MAS helps, especially if its not calibrated for the stock computer. See www.motorhaven.com/custom.htm for our custom sheet. Give us a call at 770-806-1955 on Monday and I can go over the details with you.
Sorry for the delay, been at the SEMA show.
