Request for a DRW Pickup Owner
Old Sep 20, 2021 | 09:20 AM
jade97's Avatar
jade97
Good Morning All,
I have a Request for a DRW Pickup Owner....
Could you please measure the distance between the 3 rear clearance lights (under the tailgate) from the center of one light to the next?
Thank you in advance for your help!
Regards,
Mike
Old Sep 20, 2021 | 06:14 PM
Skyler.WA's Avatar
Skyler.WA
12.5" from center of left light to center of right light
6.25" from center of left or right light to center of center light
I didn't even know I had those lights until I saw this question. Are they only on DRW and not on SRW?
Old Sep 20, 2021 | 06:50 PM
jade97's Avatar
jade97
Thank you very much!. I'm going to experiment with some 3/4" leds using the blank panel that we have on our srw trucks. That factory led bar is too damn expensive.
Regards,
Mike
Old Sep 20, 2021 | 07:41 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Yes. Vehicles and trailers over 80” wide require them. This is also why every DRW pickup has cab clearance lights on top.
Old Oct 8, 2021 | 01:53 PM
jade97's Avatar
jade97
Here it is, the $30 DRW Light Bar....(3) 0.75" holes in the blank bar under the tailgate, (3) Hopkins C2534BRK LED Lights with Grommets, (1) Molex Connector receptacle for Pin 18 underbody connector and some leftover wire, shrink wrap & loom.
Old Oct 8, 2021 | 10:42 PM
Sport45's Avatar
Sport45
Is there still a clearance issue between the blank panel and the tailgate? On my ‘19 I just removed the panel so I wouldn’t scratch up the tailgate on gravel, bark, or whatever else might land on top of the black strip.
Old Oct 9, 2021 | 08:06 AM
jade97's Avatar
jade97
No clearance issue. I used the factory "blank" to install the lights into. The tailgate folds above the blank when the tailgate is down.
Old Feb 7, 2022 | 06:40 PM
jfcody3962's Avatar
jfcody3962
Great idea, the factory light is up to $140.00
No freaking way!
Old Feb 7, 2022 | 10:24 PM
chadstickpoindexter's Avatar
chadstickpoindexter
Do you have a link for the specific molex connector and where you plugged it in?
Old Feb 8, 2022 | 05:24 AM
jade97's Avatar
jade97
Go on Amazon and search for:
Molex 20 Pin Wire Connector, Harley BLACK Waterproof, Sealed Kit, MX150 w/CPA
Old Feb 8, 2022 | 05:28 AM
jfcody3962's Avatar
jfcody3962
....and where did you plug that in?? thanks.
Old Feb 8, 2022 | 10:30 AM
jade97's Avatar
jade97
I just took one pin from that new connector and added it to, I think, pin 18 on the connector by the spare tire. There is a thread and a YouTube video showing how to connect the Ford light to this connector.
If I didn't mention it above, you need to verify the polarity of the LED you use. The ones I bought had the black wire as + and the white wire was -/gnd.
truth350
Sep 20, 2020 08:50 AM
newold46
1947 and Older Ford Trucks
Nov 15, 2011 04:52 PM
rwjejits
Aug 18, 2006 05:24 PM
Sixoh
Nov 5, 2005 01:34 PM
jade97
May 22, 2002 09:23 PM
