repowering with 390
repowering with 390
I am the owner of 87 f150 automatic with a tired 351 engine and am entertaining the idea of repowering with a 390 engine from a 76 model. Can anyone help me out here relative to whether or not the 390 will bolt right in without the need for motor mount and/or tranny modifications. The tranny is the original C6.
Thx in advance for any/all responses.
you already have the biggest engine that will bolt up to your transmission. The only way to go bigger using that bell housing is to drop a $700 stroker crank from SCAT in there and use 302 pistons with your existing connecting rods. The crank yeild 387 cubic inches without over bore, with 0.030" overbore you get 393 cid. You would also be able to utilize all your fuel injection pieces.
