Instrument panel woes
Old Sep 19, 2021 | 12:26 PM
wjstarck's Avatar
wjstarck
Hello-
I removed the instrument panel from my 1977 F150 Ranger XLT in order to install a new dash pad. I removed the stock radio and heater/AC controls since I plan to put new AC in this truck. When I reconnected the instrument panel, I noticed that the only gauges working were the ammeter, speedometer, high/low beam indicator and the instrument panel lighting. The turn signals, oil pressure, fuel level and engine temp gauges are not working. I swapped out the instrument panel for a new one and I still have the same issue. I don't see any disconnected or broken wires. What could be the issue? Do the heater controls need to be connected for everything to work?
Thanks,
Will
Old Sep 19, 2021 | 01:43 PM
beartracks's Avatar
beartracks
One might suspect the conector. Do you have a new printed circuit board?
Old Sep 19, 2021 | 02:18 PM
wjstarck's Avatar
wjstarck
Yes, new circuit board.
Old Sep 19, 2021 | 02:25 PM
meangreen92's Avatar
meangreen92
Can you put the old circuit board back in? Those floppy circuit boards sometimes changed from year to year, not the mention that there's one for full gauges and a different one for warning lights. The circuit board and its original vehicle's wiring harness are a matched set,
Old Sep 19, 2021 | 03:29 PM
wjstarck's Avatar
wjstarck
Yes, I tried putting the old one back in and I get the same result
reamer
17
Apr 18, 2017 04:57 PM
cerebixed
1983 - 2012 Ranger & B-Series
Jul 15, 2009 11:19 PM
jasonhoodenpyle
Electrical Systems/Wiring
Apr 14, 2006 09:20 PM
Night Train
Nov 10, 2003 02:41 AM
