Sponsored by: Auxito
Ignition Transponder by-pass
Old Nov 2, 2003 | 01:40 PM
ATG's Avatar
ATG
I would like to be able to make copies of keys. Has anyone installed the transponder by-pass that is used for the remote starting systems? If I install this will I be able to use un-chipped keys to start my truck? (2000 F-150).
Old Nov 2, 2003 | 07:55 PM
Racerguy's Avatar
Racerguy
Hi ATG and welcome to FTE
I've installed these with some remote starters and they should work for you. You'll probably need the kind that an actual key goes inside so the signal from it fools the system into thinking the right key is in the ignition.
zimm
Oct 27, 2014 08:52 PM
sudsmcduff
Sep 21, 2014 03:30 PM
Spotty
1997 - 2003 F150
Mar 22, 2014 07:34 AM
DirtySCREW
Escape & Escape Hybrid
Nov 12, 2013 06:56 PM
Dectek
2004 - 2008 F150
Feb 15, 2007 10:19 AM
