'66 F250 Generator Light blinking
Old Sep 17, 2021 | 03:55 PM
JayPaul53's Avatar
JayPaul53
Recently the GEN light on the '66 F250 blinks dimly...seems it gets brighter at speed. Stays on when I turn on the Emergency Flashers or Turn Signals... Brand new Battery - any ideas?
Old Sep 17, 2021 | 04:14 PM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
You have an alternator, not a generator, I believe. Can you run it by your local auto parts store? They can check your charging system, should be free of charge.
Old Sep 17, 2021 | 09:42 PM
SwampRattFord's Avatar
SwampRattFord
Sounds like voltage regulator, give it a sniff.
Old Sep 18, 2021 | 02:40 AM
thrifty's Avatar
thrifty
Check your charging system with a voltmeter to see if you have the correct voltage. Then there are other things you can check to narrow it down if it's a voltage regulator or alternator (generator?) It should be an alternator with a 66
Keith B
20
Apr 17, 2017 09:32 PM
projectdagger
May 31, 2011 03:03 PM
willmckinney76
Aug 27, 2006 02:38 PM
Rich Stenzel
Electrical Systems/Wiring
Jan 4, 2004 01:49 PM
bkc1964
Dec 31, 2003 09:02 AM
