Sponsored by: Real Truck
Acceleration Vibration
Old Sep 15, 2021 | 07:56 AM
Hopper123's Avatar
Hopper123
My 03 V10 has a vibe upon starting. It is worse when under load or starting to accelerate on a hill or from a 90 degree turn. Was moving its fine just from start to about 10-15 mph. It feels like it may be comming from the back.
What could possible causes be. Any feedback would be appreciated.
Old Sep 15, 2021 | 08:41 AM
Bigpipes 35's Avatar
Bigpipes 35
I had the exact same issue, most likely its the rear axle limited slip chattering. You could try replacing the fluid and adding friction modifier which didn't work on mine. Because my truck only sees pavement while pulling the camper I replaced the carrier with a open unit and problem solved for me.
Old Sep 15, 2021 | 01:21 PM
bajaphile's Avatar
bajaphile
Do you have any lift in the rear?
First thing I'd check is for any U-joint play by grabbing the driveshaft and seeing if you get any play there. Usually the rear most U-joint at the pinion flange is the one to go first. While your grabbing the driveshaft, check play at the carrier bearing as well.
Jack up the rear axle so the tires can rotate freely and check wheel bearing play/noise as well...
Old Sep 15, 2021 | 03:26 PM
Hopper123's Avatar
Hopper123
Thanks for the input I will be looking at it in more detail this weekend.
one other question if it is the non slip can I just replace it with a Detroit auto locker? I have them in my jeep and really like em. The ocasional clunking when I put it in drive or reverse doesn't bother me a bit. I would leave the front open dif.
Old Sep 16, 2021 | 09:10 AM
Bigpipes 35
If it turns out to be the carrier clutches then its not a non slip. As far as replacement you can go with what ever locker you chose.
Old Sep 16, 2021 | 12:23 PM
2004 F450's Avatar
2004 F450
Before you do anything to the rear end make sure you don't have one or more bad coils. Your at the age they start to fail.
Old Sep 16, 2021 | 01:27 PM
bajaphile's Avatar
bajaphile
The 2011+ Super Duty's came with an E-locker option. You can buy the carrier with pigtail for about $500. Swap over the ring gear and set the backlash, run a 12V (switched) source and you're done... (Obviously a lot of work but is what I plan on doing in the coming months, hopefully...)
I'm still not sold that it is your differential though (It is a possibility of course). Sounds more like driveshaft related or possibly wheel bearing... but hard to really diagnose without feeling, seeing/hearing it.
Old Sep 16, 2021 | 02:01 PM
Bigpipes 35
From the way he is describing it its identical to the issue I had but its always worthwhile to rule everything else out as I did. I even went so far as to have a brand new drive shaft built for the truck which didn't help anything.
Old Sep 17, 2021 | 07:38 AM
jav_eee's Avatar
jav_eee
but did you get if fixed?
Old Sep 17, 2021 | 08:23 AM
Bigpipes 35
Yes see post #2
Old Sep 18, 2021 | 11:10 AM
jav_eee's Avatar
jav_eee
Yes see post #2
I see! I’ll have to give this a try. Along with lubricating the slip yoke. I’ve got a vibe at launch.
CPaulsen
Feb 13, 2015 09:47 AM
Triboy
Mar 14, 2005 08:03 PM
pipercoal
Jan 5, 2005 09:54 PM
