Spindle Nut Torque? Hub install Procedure?
Old Sep 14, 2021 | 07:52 PM
K2thO's Avatar
K2thO
Looking for some help.
I have "new" used hubs that I'm putting new races and bearings in.
What is the correct install procedure?
What is the correct torque for the spindle nut?
Old Sep 15, 2021 | 11:39 AM
MikeyLawless's Avatar
MikeyLawless
The way I've done it for close to 50 years, and as I was instructed in High School....
Tighten the spindle nut fairly tight. Maybe 30-40foot pounds. Just very very snug will do it
Back it off. Tighten until all play is removed, and then give it about a 1/6 to 1/4 turn. Whichever gets the cotter pin hole to line up.
The initial tightening is to "Set" the bearings, and squeeze the grease out from under the rollers. Then the final tightening sets the bearing preload.
Without the first tightening, you may find that you will develop play in the bearings after a short time. This has worked well for me on every build, every trailer, with never a bearing failure.
Old Sep 15, 2021 | 12:10 PM
Thunderkiss1965's Avatar
Thunderkiss1965
^^^^He's right you know^^^^
Old Sep 16, 2021 | 06:21 AM
micc's Avatar
micc
Hi Mikey
Would you use this procedure for already run in bearings?
Old Sep 16, 2021 | 08:03 AM
MikeyLawless
I would. I always have. Pretty much SOP as far as I know
Old Sep 16, 2021 | 09:05 AM
'65Ford's Avatar
'65Ford
One thing I add is to rotate the hub in the forward direction while tightening the nut.
If you want a number for the final tightening it's around 25 INCH lbs. BTW, the 30-40 ft lbs initial is enough for front spindles. For rear spindles (like on an F250) I crank them tighter...80ish ft lbs for the initial, then back the nut off then snug it up. Seems to take more to "seat" the rear bearings.
Old Sep 17, 2021 | 11:45 AM
Greaser007's Avatar
Greaser007
Figure 17 below link, page 8, says .001-.010" endplay for a Dana 60. LoL
See page 8 of 16 in below Dana 60 Bible.
see billavista.com/forums/1674005-spindle-nut-torque _ _ _.
Microsoft Word - Dana 60 Manual _Front axle_.doc (billavista.com)
Note: in the above link, it is part 1 of 2.
Old Oct 12, 2021 | 08:06 PM
K2thO's Avatar
K2thO
Thanks guys. What about assembling the hub with bearings and seals, any tricks to it?
Old Oct 13, 2021 | 07:30 AM
lizardman1's Avatar
lizardman1
I use the Mario Andretti tool to install the bearing races. Pack the bearings with a bearing packer, then put some grease inside the hub not too much. "It will help to dissipate heat". I then install the inner bearing and seal. I use the same bearing "race driver" to set the inner seal. After that you are ready to install the hub and outer bearing. "Mikey Lawless" procedure is spot on. Then you are off to the races, no pun intended, NOT!
loudfords
Sep 29, 2023 07:55 AM
Emittim3
Feb 18, 2019 10:18 AM
1993 ford
Aug 15, 2017 09:35 PM
Rocky Mountain F150
Sep 11, 2012 07:55 PM
slowfour
1997 - 2003 F150
Jul 16, 2006 05:04 PM
