FE questions... Owner to be
She is going to need a bigger steering wheel to get those tires a turning especially when moving slowly. I recall being at a Fun Ford in my F100 and the traffic director wanted me to park "here". I was at a dead stop and there was no room to get the truck moving so I had to wrestle the wheel to turn while he said "tough to turn"? through my window.
Worked on some wiring and replaced the starter. Old one sounded weak when I bypassed the solenoid. Got the motor turning a bit. Not much or fast. Ordered a starter switch pigtail to clean things up. Lots of unused circuits on this harness.
Ok, questions for you FE gurus. I bought a set of 390 GT heads. Didn't realize the exhaust bolt pattern is different. Should I consider drilling the heads to fit standard manifold pattern headers? Drill the header flanges? I got new stainless headers and hate to send them back. Should I just bite the bullet and clean up my stock heads and sell the GT heads?
Drilled a few broken bolts before snapping a couple bits and throwing in the towel. Dropped off my original heads yesterday at the machine shop. They should be done tomorrow or Thursday.
Measured my stroke now the heads are off... What does everyone think? Is this 3.5 or 3.75ish? Bores measure 4.05- 4.06. Pistons are marked .030. Do I have a 353 bored to 360 or maybe a 390 like I was originally told? Or some other odd displacement?
I don't know if somebody got cute stamping the pistons, or if your block started life as a 352, 360, or 390. What you say you've got right now would be the stock bore and stroke of a 390.
#29
Below the adapter. Maybe E11?
Driver side front of block 352
Think this is what you want C7 BIF?
#30
