6.0 fuel starvation??
Old Sep 4, 2021 | 09:15 PM
Jack6.0's Avatar
Jack6.0
6th Gear
Hey I’m new to the site but have been using it for years now I have a problem with my 2006 F-350 6.0 with 227k miles. It will lose power and sound like it is misfiring sometimes. Completely unpredictable when it happens but it throws a contribution code for a random cylinder every time. I thought it was bad injectors replaced the 3 I kept seeing and low and behold didn’t fix the problem. So I pulled the HFCM out and replaced the fuel pump and filter both with motorcraft parts and it is still doing it. I’m at a loss right now and would really appreciate any help. Thanks in advance!
Old Sep 4, 2021 | 09:27 PM
Visurveyor's Avatar
Visurveyor
Check on your pickup foot in your tank. There's tests you can do to see if your getting fuel to pump. Could have a disintegrated foot in your tank, where your lines are picking up little pieces and clogging up.
Old Sep 4, 2021 | 09:55 PM
Jack6.0's Avatar
Jack6.0
6th Gear
Ok I’ll see if I can drop the tank what are those tests though?
Old Sep 5, 2021 | 08:36 AM
Brotherbillstruck's Avatar
Brotherbillstruck
How are your f.i.c.m. numbers looking?
Old Sep 5, 2021 | 08:46 AM
Brotherbillstruck
You can try running the truck out of a fresh can of diesel with a long hose for example. There are a few examples on here somewhere. I will look in a bit.
This is Visurveyor work from a while back.
https://www.ford-trucks.com/forums/1...l-filters.html
Old Sep 5, 2021 | 09:14 AM
TooManyToys.'s Avatar
TooManyToys.
But what you really need to do is install a permanent fuel pressure gauge.
Old Sep 5, 2021 | 11:18 AM
Jack6.0's Avatar
Jack6.0
6th Gear
FICM sits around 49.5 volts constantly. And I am thinking about installing the fuel pressure gauge as well my scanner doesn’t have fuel pressure built in to it.
Old Sep 5, 2021 | 09:18 PM
FiveOJester's Avatar
FiveOJester
Get a fuel pressure gauge before throwing any more parts at it. FYI the Edge Cts allows you to add fuel pressure sensor but it’s not cheap.
Old Sep 6, 2021 | 12:55 PM
Motohead911's Avatar
Motohead911
X3, get a fuel pressure gauge. It will help a lot.
Chuckymccabe
Dec 23, 2020 09:05 AM
bnichols
Aug 6, 2010 01:59 PM
1cebdad
Jan 3, 2010 12:55 AM
msdieseldr
Sep 25, 2006 06:33 PM
