Insulation Under the Cowl
Old Sep 4, 2021 | 02:47 PM
dwayner79's Avatar
dwayner79
Good day,
New to the forum, and just getting started on some projects on a new-to-me 1985 F-150 351w
When I took the Cowl off to fix the wiper motor, the insulation was completely destroyed/worn out. I already bought the "cowl to hood" seal, but I'm talking about the stuff that is glued to the underside of the cowl - or was.
In the picture the red line is where I'm talking about. Can I use something like high density foam tape?
Amazon.com: High Density Foam Tape Waterproof Sealing Strip CR Strips Neoprene Single-Sided Adhesive EVA Seal 1/2in X 1/2in X 13Ft : Industrial & Scientific Amazon.com: High Density Foam Tape Waterproof Sealing Strip CR Strips Neoprene Single-Sided Adhesive EVA Seal 1/2in X 1/2in X 13Ft : Industrial & Scientific
Or is there an actual kit for this?
Picture of my daughter and me is just because I'm stinkin' proud of her.
Daughter and I working on "Beatrice" That's the trucks official name!
Old Sep 4, 2021 | 03:31 PM
diggerrigger's Avatar
diggerrigger
I used some 1" square foam that you would use to seal a window air conditioner. Probably bought it at Lowes. The stuff I used was not very dense. In some places the seal has to be compressed pretty good.
Old Sep 4, 2021 | 08:13 PM
FuzzFace2's Avatar
FuzzFace2
Think I used the same thing.
While you are at the hardware store picking up this foam pick up a garage door bottom seal for the cowl to hood seal.
Do a search for this as it is a good fix.
Dave ----
Old Sep 5, 2021 | 06:13 AM
dwayner79's Avatar
dwayner79
Thank you. I bought the cowl to hood seal already, so probably just stick with that, but the 1” square is helpful. I’ll head to Lowe’s.
tradosaurus
6.7L Power Stroke Diesel
31
Aug 10, 2021 10:05 PM
Laid Back
Oct 4, 2020 08:10 PM
Odisvan
22
Nov 22, 2019 06:12 PM
abe
Dec 4, 2018 10:02 AM
Speedjester
Aug 26, 2010 10:18 PM
