Brake lines done...
#32
![](https://cimg3.ibsrv.net/gimg/www.ford-trucks.com-vbulletin/1200x1600/master_008_d9fe3dd28cb002b292ec2ae0ac4627e07be6202e.jpg)
#33
#34
All that is, is a feel good place to plug the brake lines into. Simple hardware store parts and direct feed will do the same thing for a fraction of the price. Even with drum drum setup is is still important to control the rear bias. That is why the blocks with a proportioning valve is important.
#35
That's why you replace the fronts at twice the rate of the rears. This whole debacle is unfortunate and someone near should have offered help. I plumbed my whole system including a front swap to a 79 F250 setup in 6hrs and not a single leak. Haven't even looked at it in 4yrs. Help thy neighbor.
#36
You replace the fronts at twice the rate as rears because when you stop the weight shifts toward the front of the vehicle. It’s still the same on disc/drum vehicles.
Ford didn’t put a proportioning valve on drum brake trucks. First prop valve came on F100s in 73 on disc/drum vehicles.
A prop valve isn’t necessary on drum/drum vehicles.
#37
The following users liked this post:
#38
#39
#40
#41
One stays with drums out of necessity as there are no donors in the yards around here since 2006. One is lucky to see a vehicle in Pick n Pull that is older than 1985 since that time. So with the front suspension done one sticks with it now.
#42
I hear ya, brother. We are down to one pick n pull yard here locally. I was lucky to get the swap parts for my ‘72 when I did.
#44
I would have thought the incessant wildfires would have you guys lining up at the Uhaul rental office. I lived in California from 1999 to 2007 - Chico up north; I was there for a master’s degree. Loved it - was beautiful and fun, but couldn’t afford to buy a house there so left and went back to the Appalachians.
#45
