6.7L Low Fuel Pressure
Help FTE!
Ive got a 2015 6.7L thats is experiencing some fuel pressure issues after installing the SPE Disaster Prevention Kit. I suspect it is coming from air in the fuel line, but Im no expert on these trucks. With that said, I need to know the best way to bleed the air out manually, because the whole cycle the key 6 times isnt doing the trick. Truck fires right up but goes straight to REP mode
The following users liked this post:
Hm, you would think they couldnt push this kit if it had an engineering flaw like this. Seems more likely there are some air bubbles trapped somewhere. I checked the MPROP, the fuel pressure sensor, and the fuel pressure regulator and they all check out. No visible fuel leaks. CP4 bore was spotless no chrome or dirt to speak of. and the kit doesnt choke down flow it mainly routes lubricant diesel to the top of the CP4 and put the little exofilter on the return line. Not sure why It’d be causing low rail pressure
the kit creates 2 parallel paths
apparently, the roller bearing path is letting too much fuel thru and back to the tank vs the injector path.
the oem setup was 1 serial path.
my guess is that either the holes to the injector path at the cp4 block off plate is too small, or the holes at the dividing manifold has holes too large for the roller bearing path.
some type of retro fit , like the below flow restrictor, may be needed in the roller bearing path.
I have both the SPE kit and the fen2 s&s kit. I initially bought the SPE kit, but once I heard about the low fuel pressure problems, I put the spe kit on the shelf and orders and install the s&s kit.
it’s very difficult to communicate with SPE . Good luck with that.
Since the low pressure sensor is actually on the stock path , the rail that the fuel line from the filter originally connected to….the retro fit will probally be needed I going into the exofilter.
s&s doesn’t have this problem and my guess is becuase the 2 micron return filter has sufficient back pressure to allow the low pressure fuel sensor in working properly.
Do you know anybody who has tried that successfully...or at all for that matter? Im down to try anything right now if I can get one from a hardware/autoparts store
speakerfritz
6.7L Power Stroke Diesel
08-19-2021 04:24 PM
Thenameskam
11-14-2019 07:11 AM
terrymargate
02-01-2018 08:54 AM
