I hope I can get some help with this. I bought a after market alluiuman radiator and the top of it is too big and my brackets won't fit to hold the radiator in place. Is this normal. The description said it fits my 2002 ford excursion 7.3 L V8.
Sounds like you got a 6.0 radiator vice a 7.3 one. The top tank is larger and the brackets are different to accommodate the larger top tank of th 6.0 (degas bottle and its mounting location are different too as a result).
What did you buy and where did you buy it, and can you return it?
This is the one i bought, no fitment issues, it fit the brackets more snugly that the stock rad, but not in any negative way, bolted right in, and has been rocking with my new engine without a single issue. https://www.radiatorexpress.com/prod...218053/1358119
If I were to go anything other than OEM, I'd opt for Mishimoto. Unfortunately I had to go with a Denso since my repair shop wouldn't allow me to bring my own part in and the OEM Ford they quoted me $700. It's a $500 part if I bout it myself. So far the Denso has been trouble free. As for Mishimoto, I just had a transmission cooler installed last week and not only is the quality top notch, they give a lifetime warranty.
