Brakes
Old Aug 31, 2021 | 07:19 PM
Fmc128's Avatar
Fmc128
Brakes
2019 f450, 10k mikes. Front breaks started squealing. Took to dealer and they took apart,cleaned, and lubed. Stopped for about a week now back worse than before. Any suggestions, driving me nuts
Old Aug 31, 2021 | 07:58 PM
senix's Avatar
senix
if they are still good, try a spray on the back side of them.
I forget what it is called but you could coat the backside to help with the chatter.
Have you tried to spray them down with some water when cold. In case there is some dirt in there?
Old Aug 31, 2021 | 07:59 PM
Fmc128's Avatar
Fmc128
No haven't tried that, I will though
Old Aug 31, 2021 | 08:17 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Google "brake bedding" and choose one of the bedding procedures and try it.
Old Aug 31, 2021 | 08:32 PM
Ding126's Avatar
Ding126
is the squeak when brakes applied or just driving?
Old Aug 31, 2021 | 09:54 PM
Fmc128's Avatar
Fmc128
Applied low speeds
Old Aug 31, 2021 | 10:26 PM
HRTKD's Avatar
HRTKD
Long shot, but do you use a spray on product to clean your wheels or shine your tires? I used a product once that caused my brakes to squeak bad. It caused the pads to glaze. I removed the pads, sanded them down to remove the glaze and they were fine for 50k miles.
Old Sep 1, 2021 | 04:44 AM
Fmc128's Avatar
Fmc128
Na just soap and water
Old Sep 1, 2021 | 05:12 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Drive on any gravel/dirt roads for extended periods? Dust and dirt between the pads and rotors will make them noisy too
Bernie Lomax
Oct 14, 2004 06:12 AM
