Steering columb
Old Nov 1, 2003 | 07:23 PM
Tattoo Matt's Avatar
Tattoo Matt
Steering columb
I need to replace my steering columb on a 76 f-100.. What years and makes do i have to choose from?..is there any thing i should know before this swap?..I'm also replacing my my front dash..The medal part..does any one know if 73 to 79 where all the same?
Thanks Tattoo Matt
Old Nov 1, 2003 | 10:05 PM
Stroked_77's Avatar
Stroked_77
Any column out of a 73-79 should be a direct bolt in. The wiring might be different. The dash I know for sure is the same for 73-79. Good Luck!
Old Nov 2, 2003 | 08:47 AM
73Custom's Avatar
73Custom
Keep in mind that power steering and non power use a different column, and I think 2wd and 4x4 use different columns too.
So if you have power steering, you would need a 73-79 donor with power steering, auto, 2wd.
Marty
Old Nov 3, 2003 | 11:45 AM
Tattoo Matt
thanks for the advice
Old Nov 3, 2003 | 07:51 PM
theonlybull's Avatar
theonlybull
78-79 have nutral switches on the tranny, not the colum ( auto tranny) so they won't work in the earlier trucks.
