Sponsored by: Real Truck
Front end questionable noise
Old Aug 28, 2021 | 04:59 PM
dnevels8's Avatar
dnevels8
New guy here. I have done some extensive research and can't find much of a consensus.
Background: 2008 350, recently replaced front hubs, pads and brake calipers after experiencing vibration at 47 mph+, squeezing when braking and feeling sticking braking, grinding when turning all predominantly from the front passenger side. I have unfortunately had plenty of work to do with the truck since I purchased last summer including entire new rear brake system, new water pump, new transfer case (due to a bad front drive shaft that has not been replaced, don't need 4wd right now and can't afford to have the work done). When the transfer case was done about 4 thousand miles ago I was told the hubs were on the way out and the U-joints weren't in great shape.
Just finished the front end work and while everything is much smoother (don't feel the grinding when turning, shaking, etc.) I still hear a "swoosh" sound when the wheel makes a rotation. It seems to be at the same place each time as it is more frequent when I speed up. It doesn't seem to begin until about 29-30 mph.
I know I need new U-joints and will get that done as it is out my my scope of ability, but would like to be able to make it where work can be done a bit cheaper (Not Jackson Wyoming), and that wouldn't be causing this sound would it?
The easiest fix I have found seems to be a warped rotor that might be rubbing, however it didn't seem to be, but that's not to say I just didn't notice. When else should possibly be looking at?
Thank you for any help.
Old Aug 29, 2021 | 06:25 AM
hodge5's Avatar
hodge5
Look at the dust cover, that it isn't bent and rubbing somewhere. Also check the inside of the rim for rub marks- it could be scrubbing on the caliper or something else.
GomerPile
Nov 20, 2024 01:57 PM
Shawnqualls
Jul 1, 2021 08:50 AM
jphatem
Offroad & 4x4
Mar 3, 2003 06:10 AM
jphatem
Feb 25, 2003 11:39 PM
