Wires where do they go??
Old Nov 1, 2003 | 06:36 PM
GrayRanger4x4's Avatar
GrayRanger4x4
Question Wires where do they go??
I was removing my front bumper on my 89 BII to put a custom winchbumper on it.Well when I pulled the stock bumper off there was a wire wrapped around the bumper barce on the right side.It had two oval plugs on it with two metal prongs in them {Male plugs.}I traced them back to a relay on the right side fender in front of the Power distabution box.I can not find anything that plug into.I looked at my 89 Ranger and it did not have the relay or wires.The only diffrence between the two is the BII has power windows and locks,also cruise control all which work.
Does any body know what these wires go to?I'm at a loss on this.The BII runs fine and everything works.
Old Nov 1, 2003 | 08:48 PM
Franklin2's Avatar
Franklin2
Does the horn still work?
Old Nov 2, 2003 | 09:22 AM
GrayRanger4x4
Franklin2
Yes the horns,lights,and turn singals all work.I think that it is the old fuel pump wires for the gen 1 BII,they have two fuel pumps the gen 2 only has 1. My truck was built in 1/89 so I was thinking that it was added on at the line,but mine has only 1 fuel pump so its not needed.Doese make sence or am I wrong again??
Old Nov 2, 2003 | 03:55 PM
Franklin2's Avatar
Franklin2
Could be right. I have gone round and round sometimes with Ford's "half-year" models before as far as the wiring goes. And a fuel pump would need a relay.
Old Nov 4, 2003 | 12:33 PM
armyguy's Avatar
armyguy
some models came with auxilary running lights, yours may not have been equipped but the harness is the same.
Shanook9080
Bronco II
May 19, 2014 02:46 PM
DFWBII
Bronco II
16
Jan 29, 2011 11:32 PM
jjx73
Bronco II
13
Jan 20, 2007 10:41 PM
B'II-Trapper
Bronco II
Mar 18, 2006 08:13 PM
soy4soy
Bronco II
Apr 5, 2003 04:57 PM
