If you're talking about the console safe, no. I've added the Lock 'er Down safes w/ the electronic lock to all 3 of my SD's. It's a worthwhile addition for sure. Easy to install also.
Mine is a 2020 Lariat and came with the safe, but it's listed as a separate $330 option.
I think he was questioning if it is included (as in standard) with the Lariat trim. Like on your truck, it is an added option chosen by you or your dealer. It can be added to any build that has a center console but is not included as part of any trim package.
Thanks for the reply’s. I think where I got confused was I the trim availability information it lists locking under seat storage. But in the Interior options, it lists the Vehicle Safe by Console Vault for $330.
thanks.
the locking under seat storage is for under the rear seat.
This video shows the Console Vault. It is a stand alone item that is not included on any trim level, but can be added to any trim when ordering, or as seen in the video, aftermarket. For this particular one, you must have the center console seat option. I originally included it on my 2022 XLT, but ended up removing it since I can get it for the same price aftermarket, and it is a simple install, but more importantly, it is one less thing that will hold up my build, or require my truck to be sent somewhere else after it's built before shipping to my dealer, AKA: me!
The under seat storage is an enclosed box under the rear seat in a crew cab. It encloses the space beneath the rear seat and can be "locked" (which really only locks the seat from raising up and providing access to the under seat storage area). Alternatively, it can also be folded down if you need the entire floor space in the back of the cab. I had to add this to my XLT via the XLT Value package, but I wouldn't be surprised if it was part of the Lariats and higher trim (check that though... I really don't know).
That was my point. I have the Lariat, but it's a separate option.
Originally Posted by Deano_1
Can the vault be easily removed if I decide I don't want to use it? Also, how do you lock it?
No, it's not easy to remove, but it's not that hard. That would defeat the purpose don't you think? I'd suggest going to the Console Safe site and download the install instructions.
Mine locks & unlocks with a four digit combination entered by rotating small wheels in the **** (like the one pictured above). I think there is a 3-digit option as well. I installed it myself in my '21 F350 Lariat. Installation wasn't too difficult, so removal shouldn't be hard as long as you have the combination to open it. You would have to destroy the console to get it out without it!
