Had a Chevy 4WD for a number of years. Finally saw saw light and got a F250 4WD. The Chevy had nothing but the electronic switch on the dash. The F250 has the switch and the manual locks on the hub. I am a little confused as to how you are to operate the 4WD. A simple explanation for dummies would be appreciated
The hubs are on a vacuum system. They will automatically lock and unlock when you turn the ****. You can lock/unlock the hubs manually if the vacuum system fails.
So as long as the selector switch is working properly then dont mess with the manual hub selector **** in the center of the wheel correct ???
Not exactly, as long as the vacuum system is working you shouldn't need to manually lock the hubs. If the selector switch in the cab stops working then you wont be able to switch into 4wd.
I’m not sure this is totally correct….if the vacuum system fails then you can manually lock the hubs to engage 4WD. The selector switch on the dash is just the the “slick” (ie lazy) way to engage 4WD, but you could manually lock the hubs each and every time you wanted to use 4WD if you were so inclined to do so.
Ok, let's put it this way....don't touch the switch on the dash, go out and turn the hub dials to manual and tell me if you are now in 4wd....you won't be.
The vacuum system and the switch have two different functions.
Well kind of... The dash switch activates the vacuum system which locks/unlocks the hubs AND the transfer case shift motor which engages/disengages the 4wd.
Funny how something so simple gets so complicated...
To the OP, you do not have to touch the hubs unless part of the system fails.
If I am off the road say hunting in the woods I normally lock the hubs when I start out. Then I use the switch to engage and disengage 4wd. When back to normal roads I unlock them and just use the switch to engage and disengage 4wd.
I'm not confused on how that works. You might want to address the previous posts where the confusion seems be, since apparently my replies weren't clear enough.
I wasn't singling you out for sure, several of us contributed to the confusion I think. I just found it funny how we all were trying to give the right advice but it came out kind of confusing....
Ok, yes, I’m on the same page now. You’re correct.
Ok…. So now I need to be clear because it’s been a LONG time since I’ve messed with manual locking hubs.
It sounds like the switch will lock them in, but using an electrical / vacuum system. OR, you can mechanically lock them in using the hubs for a more robust connection? … but either way the switch is what activates 4WD / power to the front axle. Right???
Correct. I am not convinced there is a more or less "robust" connection. Possibly a good idea to ensure they do not unlock while working the truck hard but most people never touch the lock outs. I will have to train myself not to as my current truck is manual only. Unfortunate I couldn't order a new on that way anymore.
