2004 IPR in 2003 engine -will it work?.
Hi all,
I’m in a bit of a tight space right now. As a Norwegian with only access to Chinesium buildt parts as Clay is out of stock - I’m in need of a OEM IPR 3C3Z9C968AA -for a 03.2003 buildt 6.0l PSD.
I have several of the later 5C3Z9C968CA - IPR for the 2004 or newer - will one of those work on an early buildt 2003?.
Thanx - Helge
Thanx - Helge
Hi all,
Thanx - Helge
Thanx - Helge
Mate - we are rocking the same boat - for sure.
I’ll check out the link
If you PM me - we maybe could exchange some details.
Takk for tilbakemeldingen,
Helge
Should work fine, as best as I have found the difference is that later IPR holds about 200 psi on the system when fuliy open and the older version releases. This would not be a problem at all
Thank you for your replay.
Helge
kerry stepp
Mar 13, 2020 03:09 PM
taco
Sep 20, 2003 01:11 PM
